I could not hesitate to pull the board out of the case and take a look, so here my review about the hardware part:
The controller looks very well designed and assembled with care.
I could see the power stage has following features:
- high quality low ESR electrolyt capacitors
- ceramic caps near the FET's
- large copper bus bars (looks like a "sandwich" board with a thick copper plate between)
- a real shunt resistor (not just a copper bus bar)
The display top cover looks nice, however the bottom covers look 3D printed and reworked with hands. We should be aware that it is still beta and this will probably be fixed in future.
check out the pics:
If you wanna compare the size with Adaptto, the Nucular 12F would be the competitor of a Mini-E then, but WAY MORE powerful
Adaptto Midi, PV (Infineon) 12F, Nucular 12F side by side:
I wanted to have it plug and play with my actual wiring on the bike for an easy replacement, so installed an adaptto throttle/brake and hall sensor connector. On the supply wires i used 6mm bullet conenctors and also added the wiring needed for charging on the controller side.
The display as ALOT of IO ports which can be defined in the Display menu settings.
For instance i installed a button to scroll through the three power modes to IO1, Domino 5k throttle and variable hall sensor E-brake.
The autodect function detects the throttle and brake range and it worked flawless from the first time. No need to set limits or anything like this.It just works
It can be mounted to the bike by using GoPro steer tube holder (which was included):
here the screen when powered up and during charge:
the color of the four buttons on the display can be configured which is indeed a nice feature, and other things like brightness of the screen and buttons can be adjusted too.
