i want to build a large motor to lift up things of up to 60kg ..
what do i need to have to make this project?
ES DIY Motor Challenge
Re: ES DIY Motor Challenge
Massive gear reduction and move the load slowly or huge power and low kv to move the load faster.
What is the 60kg a brief description of what your attempting, 60kg can be lifted with a remote control car motor if the gearing is like 100 to 1 there's a guy on YouTube that has exceeded that lift weight with Lego parts alone.
- ElectricGod 1 GW
Which do you want?
Fast lifting or slow lifting?
Fast can be done, but you need a big motor and strong parts.
Slow needs lots of gearing to take whatever torque source you have and gear it down enough to get it to lift the weight desired.
A CD ROM motor can lift a car with enough gearing.
XB-502: viewtopic.php?f=10&t=83302&p=1222730#p1222730
Currie scooter: viewtopic.php?f=35&t=83830&p=1227407#p1227407
Benjamin Franklin - "Any fool can criticize, condemn and complain and most fools do."
