Nucular electronics - complete kit for ev!
VasiliSk said:
ElectricGod Sorry i may be missed question. 12F and 24F have same control board, check schematic, only difference is PWM connector got wider (v2.5)
Quokka Thanks, you can connect variable brake same way as throttle, use display BRK port or controller BR port
Thank you...that was my guess.
One year and a half with no issue
With 2 x 12F there's torque for sure. Waiting for the 24F on rear wheel to carry... maybe a mobilhome ?!!
https://youtu.be/KioDNWrlIoI
VasiliSk said:
No much, been working on new 6F version. after launch will switch to bms
Will the new 6 fet be designed like the 12 and 24 fet with daughter boards?
i have "maybe" something for our wishlist.
in short: a power limit option for each mode.
we all know how nice is the first miles with a fresh battery. and we all know how it sucks when your on 30% Battery left.
you miss some couple KW of Power because your Battery voltage drops 15/16v.
if you had the option like on the old cycle analyst setting a power limit you could open the amps in all modes fully and
only limit your modes to power. Voltage drops, power stay same from first to last mile your bike feels all the time same.
Since OP stated no CA is needed, I assumed that was already an option.
If I only want to buy controllers that are compatible with CAv3, would these qualify?
The CA is OLD tech. IMHO, it needs a refresh.
At least a higher def color display that is bigger.
They have not seen new development in many years.
They will work with an external shunt on anything.
There is no CA connector, which is what you are really asking about. There's no point. You won't need a CA in any way. 100% of the functionality of a CA is built into the controller and LCD and done far better!
This is just one of the screen layouts you can select.
I don´t really get it, you want to limit the power so it sucks all the time instead of just when you are running out of battery?
I think there are a function already to keep the speed the same with field weakening when the voltage drops.
i dont really need "max peaks power"
fully 20s = 79v x 150 = 11,8kw (including vdrop)
30% 20s = 64v x 150 = 9,6kw (including vdrop)
this difference you notice pretty good.
if you limit your ride to 9.5KW you have not the feeling of losing power =)
iam talkin about power...not speed.
got it? :mrgreen:
edit:
btw. flux weaken suffers the same on lower voltage.
if your bike runs 100kph on fresh battery with flux it will hit only 90 on lower battery(voltage)
got it? :mrgreen:
edit:
I'm with Bjork on this one. I'd rather have full power when I can have it.
Maybe what you should do is implement the 3 speed option.
Make one of the switch settings be that 9.6kw so you get the same ride quality at all battery charge levels.
Make another switch setting where you get 11.8kw.
Make another into limp mode where you can still ride, but battery usage is pretty low.
interessting. how you setup 9.6kw/11.8kw? :D
Look at the schematic. It shows you the connections to use for 3 speeds. The rest is settings in the controller.
Merlin said:
Show me where you can setup a power level and not amps :wink:
It's not the button question.
You have options for different phase amps and motor speeds. I forget what the exact section in the config is, but I thought it was pretty obvious once I was looking at it. They are like 3 profiles...A,B and C or something...lol...that's not it exactly...I'd have to go look. I know that's not super helpful, but it was a while ago that I last set up this option last and have since forgotten the specifics.
What your butt feels is torque response, right? And this is related to available torque (current) and this is related to the drive voltage which cannot (ultimately) be kept constant without rpm limiting.
I can’t see what a constant x kw setting would give?
What did the CA function do that isn’t already done in a torque throttle controller?
Merlin, I'm not sure what you want. Personally I agree with the opinion of Electricgod. On speed 1 you can choose the battery and phase intensity as an ECO mode. You can choose the other 2 speeds with higher battery intensities and phases. Isn't that enough to do what you want?
Isn't Nucular a true FOC controller? aka flux-vector control
Correct me if I'm wrong but my understanding is that means not just manipulating gross current levels to influence torque, as with the CA, maybe similar to "sinusoidal commutation" controllers?
But much more precise control based on monitoring of current sensors internal to the motor,
and powerful CPUs to process the signal data, predicting the rotor angles real-time.
If this is a reasonable description, then all such FOC controllers perform this functionality better than the CAv3 can?
But the issue here is that control based on **power**, watts as opposed to amps, simply is not useful?
Just trying to grok the fundamentals here, appreciate the feedback.
Whether it is a real FOC or a fake when I activate the function f w I gain 10 km / h. If I understand correctly Merlin asks for a configurable Fw for each speed one two and three?
Field weakening isn't magical.
It costs you more current to use it.
You lose motor efficiency to use FW.
I can't say for your motor and how effective FW will be for you.
The ideal motor for FW is an IPM inrunner.
You need exposed iron in the armature for it to work.
The magnets are literally in the way of using FW effectively.
This is why IPM motors are the best option for FW since the magnets are inside the iron.
My best suggestion to you is try FW on your motor under load.
I have attempted to use it on several outrunners and the RPM gains were so small as to NOT matter.
I tried it on a couple of inrunenrs and they were a bit better, but still not worth using FW for greater current usage.
I have never tried it on a hub motor, but they too lack lots of exposed iron so I don't expect much.
FOC is definitely the best motor control around since it is the most precise and controls motors the best.
However FW has nothing to do with FOC. Trapezoidal and sinusoidal controllers can also implement FW.
I'm not sure how a CA can possibly implement real FW or phase current control. The CA would need direct access to the halls and phases to do this. I just looked at the latest CA manual and it operates as I expected. There is no conceivable way it can implement field weakening or phase current control. It just doesn't have that ability. A CA can create throttle curves. Even with a 3 speed switch, it is only controlling throttle voltage. It has no way to control phase amps or FW or hall delay/advance. A CA uses a shunt in series with the battery and controller or the shunts inside the controller for detecting battery amps. This is NOT the same as phase amps or controlling phase amps.
Watts = volts X amps
Battery watts = battery voltage X battery amps
Motor watts = battery voltage x phase amps
If you look at a lot of better controllers, they have a shunt or current sensor on each phase connection. They are used to directly measure phase amps for each phase and that gives the MCU direct feedback on what the phases are seeing for current. The Nucular controllers use shunts on the battery side and some math to calculate phase amps. It's just one of several methods to get phase amps.
not sure how i can explain better than i did.
its not only related to max power. if you setup "S1" as your ECO Mode with 50A Battery, "S2" Daily Mode 200A, "S3" FuckAllOthers mode 350A
you have in each mode the same problem. A Fresh 100% Battery has more Power than an Empty Battery.
I see that Commuters or "Car-Drivers" dont see much difference. The "normal" guy could even use a "Speed Throttle" Bike and get used to it. (heres the place for a puking smiley) :p
But if you ride Offroad, Trial or other technical stuff it just needs some extra "attention" to compensate your weaker getting bike.
The Bike just feels different. Its an option. Nothing more.
How much of NUC users Ride Speed mode
How much of NUC users Ride Torque mode
How much use the Controller to charge the Battery
How much dont care about because they use the normal Battery charger.
NUC has features, some use them, some not. A Power limiting option would be Nice. thats it.
not speeeeeeedddddd.....Limit your Modes to POWER not amps =)
NO SPEED IS HERE INVOLVED GUYS.....NO FLUX WEAKENING EITHER :lol:
I think you are partly wrong, speed is involved.
I may be wrong, but I don't think the amps differ from a fully charged to a almost empty battery.
But voltage does. That means that you will loose speed and power at higher rpm.
The lower rpm should be about the same.
So what you want is not really a power limiter, but a output voltage limiter.
