Stevebequik
- Joined
- Mar 18, 2019
- Messages
- 36
Stevebequik said:7C22DB7C-1B67-40EB-B33B-55F9A1096359.jpeg
QSMOTOR said:ctirad said:QSMOTOR, do you plan to alternativiely equip your MID motors by SINCOS encoders instead fo halls?
Yes, for our new 180 90H 9000W mid drive motor we will use encoders instead of hall.
macribs said:QSMOTOR said:ctirad said:QSMOTOR, do you plan to alternativiely equip your MID motors by SINCOS encoders instead fo halls?
When will this motor become available? It seems there have been nothing but picture of this motor on your website for the past 6 months. Still no specs, no motor data, no graphs. I hope you can update us with more information on this new motor.
QSMOTOR said:QSMOTOR 180 9000W 90H PMSM IPM mid drive motor
For a long time, we are developing and testing our new 8000w mid drive motor, below is the result
For Motor
Item: QSMOTOR 180 9000W 90H PMSM IPM mid drivemotor
SPEC
·Motor Type: PMSM IPM Motor With Hall Sensor
·Rated Power: 9000W (18000kW peak in few seconds)
·Rated Voltage: 72V
·Speed: 4000RPM peak (basic RPM), 7000RPM with flux weakening
·Max Torque: approx 100N.m peak.
·Max Efficiency: approx 95%
·Continuous Battery Current:200 A (72V)
·Peak Battery Current: 250A (72V)
·Working Temperature: 70-130℃ , peak 180 ℃
·Single Hall Set with waterproof connectors
·Waterproof Grade: IP67
·Cooling: air cool
·Dimension: φ200X280mm
·Phase wire: 22mm²
·Insulation grade: H
·Working system: S9
·Color: Black
·N.W./G.W.: approx 25kg
·Package Dimension: pending piece
PS. For 180 PMSM motor, it’s maximum 135H 12000W motor.
[/snip]
QSMOTOR said:SRFirefox said:I'm very excited for the new 9000W 180 135h mid-drive. When will it be available and is there a known price for them yet? Will they have one or more temperature sensors installed from factory?
The 9000w 180 mid drive motor is available for market, the production time is about 1 month, the unit price is $650/pc
It can match with EM72300P controller, the unit price is $558/pc, EM96300P is $578/pc
Yes, it will add temp sensor.
SRFirefox said:QS is apparently only advertising their new 180 90H motor on this forum. Who knows why. They apparently also have a 180 135H good for 12kW continuous, but no details.
