PandaYeti said:
Turned out that the stock controller firmware seemed to be buggy. With a fully charged battery it just refused to do anything. After discharging it a little, it started to work again. With the open source firmware installed, it works perfectly.
Thanks a lot!
Its not the software, its the voltage sensor that miss reads. If on some occasions the battery is over charged and the voltage sensor over reads, the software reads the voltage as being too high and the display works but not the motor. We have one such motor in our group which over reads the voltage by 0.15 and the same owners battery charger is about 0.05 volts to high on shut off. The motor won't work in this situation with a fully charged battery.
The OSF software ignores the top voltage and cures the problem.
