Lightbluemk2
- Joined
- May 2, 2020
- Messages
- 12
There isn't enough room for the MXUS and a 5 speed freewheel, I am un aware if MXUS makes a 3K motor thats compatible with cassettes. If they did, you could use a 9 speed cassette and remove some of the cogs to make a narrow 4 speed, you will need to limit the derailleurs movement with the set screws, and your would only use 4 speeds of of your 9 speed shifter as well. I have done this and its a pain in the a$$ to get things to work and shift properly. Anyway, this can't be done with a free wheel because of the fixed width of the cog shaft and spacing.
Thanks Rix, any motor recommendations for equivalent output to the MXUS for a 135mm dropout?
