LightningRods said:
A number of people have done builds with my Big Block and Rohloffs. To my knowledge none of them have broken. The stock shear pins are plastic
Good to know, thanks for that!
> A smaller wheel is like lower gearing. It reduces top speed and increases torque. That’s mostly a hub motor issue since that’s the only way they can change gearing. With a mid drive, choose the wheel size you want and then choose the correct sprockets for the gearing you want.
THANK YOU for explicitly confirming that!
> You can upgrade to aluminum pins which increases the torque limit and reduces your chances of getting stranded with blown pins.
Sounds good, so long as they are certain to still protect the hub's gearing - are they engineered by, or at least informally accepted by Rohloff itself?
> I don’t recommend spinning your wheel in a rut on a steep hill to test them.
Well not intentionally
> The easy way to take some strain off of your driveline is to have a simple multifunction switch with different power settings and throttle ramps.
That sounds perfect! Would allow the gearing ratios to be selected more towards optimum performance once underway
with the (maybe greatly) reduced power settings available for protection during those uphill-facing standing starts
take maybe even a few minutes to get up past that 8-10mph "hump", then "shift" up to full power to get to 15mph, if the weight/grade allows.
My understanding is, once at those more reasonably high speeds, that each speed increase is requiring a safer lower amount of torque?
I have no interest in burnouts using such strong chains, in fact, I'm thinking the Gates belt drive might help absorb the "shock effects" of low-rpm high startup torque - what do you think?
