Ugh.. It looks like my sprag clutch is fine and it's the whole assembly that moves, big gear and clutch together. There's 0.2mm play in-out which I guess due to a loose fit of the sprag clutch on the axle translates to a larger wobble on the outer spider/chainring.
Since mine is a newer model I don't have the shim(s) between the big gear and sprag clutch as seen in Jbalat's video still below.
A shim of 30mm ID x about 40mm OD is required, I ordered 30 x 42 in a few thicknesses and plan to fit behind the circlip rather than between the clutch and big gear.
This previous discussion relates to fitting shim washers on the non-drive side and I have a second bearing coming for that side, so I've grabbed some shims too. That link says the non-drive side shims should be 16mm ID x 22mm OD, any reason for this? I thought 15mm the same as the shaft would be better.
https://endless-sphere.com/forums/viewtopic.php?f=28&t=79788&p=1512178&hilit=shim#p1512178
In addition to all this, with the big gear removed the pinion gear spins freely with minimal effort and locks up in reverse. So my concerns about that causing increase pedalling effort are unfounded. Could the difference between helical and straight toothed gearing somehow be why some people report difficulty and others don't have any complaints?
