48V 500W vs 48V 1000W geared hub motor?
Tommm said:
The cells are unlikely to be rated even 10a max, but you will be drawing 10a+resistance losses from them, with the 48v battery, each cells sees 8a max.
You may wish to check your calculations, I make it 5.5 amps max draw per cell for 14S4P & 4.4 amps max for 14S5P (+resistance in both cases). Yes the 48c battery has more capacity, but the 52v will provide more speed; you pays your money, you takes your choice.
Yea I calculated the values for the 40a controller... the 500w kit comes with a 22a.
Still 52x19.2=998 vs 1152 Wh... easy choice for me for $30 extra.
Is it 8% more speed with 52V as stated before? What is the top speed approximately with 48V Vs 52? Good quess is enough
Yes, a shade under 8% faster, I can tell you how fast mine goes (as I did), but not the one you're looking at, you'll need to ask the seller what kv (revs per volt) it is, then it can be calculated, well the no load speed anyway.
Actually I find out this thread here where are some specs of XF15 but I don't understand them myself. But it seems like motor is capable at least 45km/h and over 60km/h wheel in the air and at 48V it can put out 1200W: https://endless-sphere.com/forums/viewtopic.php?t=103376
Here are the specs:
mechhead said:
Here is a new geared hub I've been looking at as something better than the swx bafang for a variety of reasons that will become aparent.
having ordered two to test and hot up, they arrived swiftly direct from mxus factory
Photos to come
a cassett version to go in a wheel with steel gears (aliexpress) 47.5mm dia 36t
and a freewheel threaded version to convert to a crossbreak style mid drive
inside the motor
6 turns 10 strands .5mm copper
the usual nylon gears
a multi screw mounted sun gear ( good potential for regen mod )
20 pole 18 slot 120mmx18mm stator with .35mm laminates
it was a small battle to work out which version of this motor has the meatiest windings
when asked about motor speeds i eventually got the spec sheets for their two fastest motors
and they claimed that the 48v 386rpm version was fastest so i asked for the spec sheet for the fastest 36 volt one and ...
48v 386 rpm
36v 349rpm
ok convert to kv and actual motor rpm gear ratio 5:1
so motor a (48v 386rpm 10t) 5*386=1930 rpm of motor @48v
to derive KV : rpm/volts 1930/48=40.2833 rpm/v
so motor b (36v 349rpm 6t) 5*349=1745 rpm motor @36v
to derive KV :rpm/volts 1745/36=48.47222 rpm/v
so we have a winner the badly named "36v" motor is the badass with 6 turns to the others 10
so speed it up to 48v
motor b (36v349rpm) take motor KV and multiply by new voltage of 48
48.47222*48=2326.667rpm now add gearbox reduction to give hubshell rpm or that of thebuilt wheel at noload speed and you get 2326.667/5=465rpm of wheel
so to compare motors properly at same voltage noload speed and you get
motor A (48v386rpm) @48v = 386rpm
motor B (36v349rpm) @48v = 465rpm
so commutation frequency 2326rpm X 10 pole pairs / 60seconds = 387hz
correct me you lot if im wrong but isn't 387hz a way short of sensible frequency limit for .35mm lams ?
what if we delta it
any here are spec sheets of motor load curves if i can make the attachments work
valsam said:
I orderd this kit https://www.aliexpress.com/item/4000258829938.html?spm=a2g0s.9042311.0.0.40ae4c4dHdGRlT and from what the seller told me the motor is this one https://www.aliexpress.com/item/32825136459.html?spm=2114.12010612.8148356.1.723776ddeHfVDK
witch it says it is 48V Cassette 425RPM .
So mechhead it looks like mine is the motor B (36v349rpm) @48v = 465rpm one.
(Customer reviews say that At 54 volts on the idling bike gives out 63 km/h(about 39 mph) on a 28 "wheel,and real top speed on 28" or 700c wheel is 44-46km/h(about 28mph).
I don't have the time to read the whole of that thread, but having a quick scan though it, it appears that someone may have had problems with their battery; I was already going to suggest that you consider upgrading the battery to one with decent, branded cells. If you get one of those in the listing you will have either 56 or 65 cells and it only takes one of those to go bad and you have a useless battery; not good odds with cheap Chinese cells!
Reading the listing again, it does actually state 440 RPM @ 48v; multiply that by the circumference of YOUR tyre, measured in meters, multiply by 60, then divide by 1000 & you have the no load speed in KPH for a 48v battery. If you want the figure for a 52v battery, divide the speed calculated for the 48v battery by 13, then multiply by 14.
Actually his problem wasn't with battery after all and no need to read whole conversation Quoted the spec parts in my post. Where would you suggest to get battery? I'm open to other battery options also.
The problem with what you quoted, was that there was some confusion as to which motor you would be getting; motor A or motor B, so I had a quick scan of the thread, but there was too much there for the time I had, so I looked again at the Ali-Express listing and the specs were there 440 RPM @ 48v.
I'm afraid I can't help you with respect to an alternative battery supplier, but there's bound to be one somewhere on Ali. The problem you will then have is trying to get an equally neat installation, with the controller integrated into the battery pack etc. You could ask ChamRider if it's possible for them to supply branded cells or check with them the warranty situation with what they supply. Personally I would much prefer branded cells, but as with the 48/52v decision, it's up to you & obviously depends on your budget too.
Sorry forgot to say that what I'm looking at is presumably option B. I think I'll just try out my luck with these Chinese sells.
Laissez said:
Tommm said:
Laissez said:
I was looking at geared motors for their smaller size, lighter weight and better hill climb for occasional climbing. Most direct drives i've seen are huge plates. Also their dd sets doesn't have waterproof connectors and battery integrated controller. Chamrider 500W MXUS XF15C has 52V 19,2Ah is 14S4P / 48V 24Ah is 13S5P battery options. Is the 48V option better as you stated with the 1000W kit?
Yea, it looks like the xf15c will be your best bet. The 48v is better just by looking at cell type being the same and getting 0.7kg extra pure cell weight. Have you heard anyone say I wish I had less range?
Don't bother with the charger upgrade, you can get a 5a pink metal charger for the price of the upgrade alone.
I would pick up a set of cogs though.
https://aliexpress.com/item/32830428964.html
Yep overall that xf15c kit looks like the best. Thanks for your tips and help. I'll post here when the kit arrives.
Got my kit, so far so good
https://endless-sphere.com/forums/viewtopic.php?f=3&t=103169&p=1584278#p1584278
Ok I bought the 48V 24Ah XF15 kit after all. Thanks for all help! I'll update after I get the kit. Any recommendations for torque arms?
I was thinking about 2x of these: https://www.ebay.co.uk/itm/14mm-E-Bike-Electric-Bicycle-Universal-Torque-Arm-Front-Rear-Cycling-Accessory/114328022267?var=414573811799
Suggestions for how to fit the battery? Should I drill new holes or zip tie it or something else?
img_20201111_192514-jpg.479773
Got any tips?
I use hose clamps and a dollar store rubber mat to help protect the case from marks
for my similar style battery in a case like yours.
Plastic zip ties will break
Plastic zip ties with metal locker will break
Plastic zip ties with a load rating of 100lbs will break
Plastic zip ties of any sort are super easy to twist off and break by a thief. Had my old battery stolen that way, though I had 2 on for range testing purposes.
Metal zip ties could work well.
Hose clamps are the best, though a bit bulky on the locker part.
You could look into the mounting mechanism for that battery case. I know I bought a mounting mechanism for my http://www.ebikes.ca/ battery, havent used it yet.
For Grintech batteries
https://ebikes.ca/shop/electric-bicycle-parts/battery-accessories.html
edit
I have been thinking of a way to mount my battery case. Heavy duty T-bolt clamps to fit around bicycle tube, drill a hole in the clamp and figure out a way to use a bolt to mount the battery case. The head of the bolt would be against the bicycle tube with the threads sticking up, then find a way to mount to holes in bottom of case.
Got any tips?
[/quote]
edit
Got any tips?
[/quote]
[/quote]
Thanks I'll look in to your suggestion and forget about zip ties. I'll definitely try hose clamps.
Something like this could work also? it seems to move the original bottle holder holes.
https://www.bikester.fi/708317.html
I found there to be a problem with the battery moving position and the problem was I did not have the hose clamp tight enough. I had mine on the top of the top bar, with other square battery inside the triangle. I was paranoid that I would do it to tight but Grin makes quality products and wouldnt enclose their batteries in substandard battery cases like some other sellers do.
As for your link, I wouldnt trust that to hold up. Batteries are heavy. I'd be afraid the standoffs would break. I'd be good to copy that, but I wouldnt buy that.
I would encourage you to consider how you are going to stop a bike going 25mph reliably, in year around weather conditions.
Myself, I would not consider a bike that didn't have disc brakes.
I have hydraulic disc brakes on my bike.
Got any tips?
Sure I got tips.
Cargo strap on the green lines.
Cut off the blue part on the bottom. It gets in the way for the next step.
Drill holes into the alu 2 places on both sides, where the pink marks are. Use steel zip ties to wrap it through the holes and around your BB cups, this makes sure it doesn't hang to one side or slip out of the cargo straps.
Got any tips?
Sure I got tips.
Thank you, I think I'll manage to do something with these tips.
Wait! There's a much more elegant way. Rivet nuts, sometimes called Rivnuts. Bike mechanics commonly use them to repair broken/stripped water bottle holder bosses.
5mm is the normal water bottle holder size, you could probably fit 6mm into your frame if you want beefier. My 10 lbs. battery is doing fine with two 5mm rivnuts, although I am not wailing on it on technical tracks.
Not hard to use. Carefully drill the hole, insert the rivnut, set it with the setter tool (or use a longer bolt, nut, and some appropriate washers).
Rivet nuts generally available at better well-stocked (real) hardware stores, or online.
You'll find plenty of rivet nuts installation tutorials on the internets.
Is my torque arms correctly installed? I got them for both sides for maximum security:
E: just realized my torque arms are for 14mm axle and my axle is 12mm. Need to get new ones it seems.
Thanks, I'll do this maybe later, but I don't want to drill new holes at the time. Got few of these to mount the battery: https://www.tweekscycles.com/uk/zefal-gizmo-iii-universal-cage-mounts-chizc199a/ and using stainless steel zip ties instead of plastic ones.
^Also get a smaller hose clamp. If that one is fine, remember to cut off the trailing unused tail of the hose clamp but till have enough clamp length to reuse it. Its a fine art to decide the proper length back there.
Some hose clamps have too much space with no track slots between where the track slots end and the screw jack. If you want to save the paint on the frame, use a piece of rubber or just fold over some duct tape and wrap around the frame stay.
Me, I just grab some steel that is 1/4" thick, but 3/8" may work but be sure there is enough beef. Angle grinder to make slots. I found with the various forms me ebikes have been in and bikes on, bicycles have a different orientation to how the dropout axle slot is. The good news is sometimes I got lucky and it would match up kinda close to a seat stay or chain stay and hose clamp it on making sure the axles been rotated the proper way in the slack. I found a little bit of slack in the axle movement really was all the bad and didnt really chew up the dropout axle slot on the frame all that bad. To each their own. I never bought no torque arms, just bought steel, cutoff wheels and hose clamps. The steel needed little notches for the hose clamps not to slide off.
Maybe if you used three or four high quality stainless steel hose clamps. and rubber to help grip the frame. I think I am going to set up a kind of ghetto bike like that and try and sell it. I have too many bikes right now and trying to get an MC to enjoy AMericas interstate now that I am licensed again. The battery would be hose clamped midtube. Rubber will keep it from sliding I believe. Cheapest best option.
Or I might keep it. I think riding bikes is better in the rain than the MC. MC is too damn heavy, also for short trips the bikes are better.
Yeah I'll think about that mid drive option also. I'd want to just stay in 500€(595$) range. Seems like my options are going with mid drive or that 500W kit. Also I'm pedalling myself a bit so 500W could be ok? Both these 500W kits seems to have waterproof higo type plugs. I weight 80kg(176lbs). Di some research also and MXUS is XF15 model and Bafang is SWX02 presumably.
What do you think is Bafang 500W or MXUS 500W better?
Bafang:
MXUS:
BBS02 mid drive with only 12Ah battery would be almost 600€(712$).
Or
BBS02 kit: https://www.aliexpress.com/item/32852257691.html 347€(412$)
https://www.aliexpress.com/item/4000772417486.html 19,2Ah 48V Hailong battery 285€(338$)
The 1000W Ali Express Kit looks like it has a 9-speed freewheel on it. Which means it's not compatible with a cassette. And some people don't mind that but I certainly do.
If you want to take a chance and have more power, go for it. If you want to play it safe, Bafang 500W geared hub. I have the front version and it's nice on the street, better than some may think offroad too. In fact you may want to do a front hub with that type of street bike. Don't put a mid-drive on a bike like that with a rigid front fork. No need, stick with a hub drive on the street.
