Shave seat tube???
JeffnAZ   10 mW
Shave seat tube???
Post by JeffnAZ » Nov 20 2020 7:24pm
I'm getting a bike ready for a E build and one of my goals is to get the seat as low as possible. I'm thinking about cutting a little off the top of the seat tube to achieve this. Anyone try this???
Couple pics... was thinking shave just about a quarter inch (6mm) off the top. It should still clamp without cracking anything i think.
IMG_0655 copy.jpg (194.42 KiB) Viewed 358 times
IMG_0656 copy.jpg (223.63 KiB) Viewed 358 times
IMG_0659 copy.jpg (152.5 KiB) Viewed 358 times
IMG_0660 copy.jpg (279.84 KiB) Viewed 358 times
Thanks for any wisdom.
efMX Trials Electric Freeride   1 MW
Re: Shave seat tube???
Post by efMX Trials Electric Freeride » Nov 20 2020 8:51pm
I did this with no regrets (so far)..
in my case used a bit larger frame for more battery space and a lower seat to bar height (than I would for a pedal only bike)..
some ride & sk8 videos:
metacafe.com/channels/NATAS666DAMIEN
http://www.youtube.com/natas666damien
i have nothing for sale.. :)
spinningmagnets   100 GW
Post by spinningmagnets » Nov 20 2020 9:45pm
I did that years ago, and no cracks have formed. Seat tube still works fine.
JeffnAZ   10 mW
Post by JeffnAZ » Nov 21 2020 5:17am
Lol... thanks folks. Thought for sure this idea was going to be criticized. But no. I’m not the only person to think of cutting down a seat tube for a fraction of an inch of adjustment. Awesome.
JeffnAZ   10 mW
Post by JeffnAZ » Nov 21 2020 5:23am
spinningmagnets wrote:
Nov 20 2020 9:45pm
Thanks! Did you happen to extend or modify the split on the back of the seat tube that allows the tube to clamp down?
Post by spinningmagnets » Nov 21 2020 7:53am
I wanted the seat as low as possible.
Slide the clamp down as low as it would go to mark a half-inch above it.
Remove the clamp
Slide an automotive hose-clamp onto the tube (to where the seat clamp was) to act as a guide for the hacksaw.
Cut the tube at the mark
Cut a slice down the back (angle grinder with a thin blade or Dremel), and it's done.
JeffnAZ   10 mW
Post by JeffnAZ » Nov 21 2020 10:56am
Nov 21 2020 7:53am
I wanted the seat as low as possible...
Thanks, man. Enjoy your weekend!
JeffnAZ   10 mW
Post by JeffnAZ » Nov 22 2020 11:51am
Nov 21 2020 7:53am
Thanks! Result is perfect. The hose clamp guide worked great! Removed 5/8" (~16mm). Could have gone lower but I couldn't bring myself to drill a hole in the flag.
Couple pics.
IMG_0660 copy 1.jpg (257.26 KiB) Viewed 244 times
IMG_0664 copy.jpg (277.52 KiB) Viewed 244 times
Post by spinningmagnets » Nov 23 2020 1:43pm
I like that you drilled a hole at the base of the split-cut.
If you didnt, a "stress riser" might develop, and a possible crack might grow in unpredictable directions...
JeffnAZ   10 mW
Post by JeffnAZ » Nov 23 2020 5:19pm
Nov 23 2020 1:43pm
Thanks... exactly why I drilled it. Your help and interest is much appreciated.
