Hey everyone, I'm building the voilamart stealth bomber. It came with an ignition and keys, it has 2 wires 1-red and 1-white, anyone know what wires i hook the up to?
My bike has an internal controller
Ebike ignition
Re: Ebike ignition
I use a sabvoton and there's a connector called 'e-lock' which disables the controller until the two wires are connected by the ignition switch. Your controller might have a similar connector or it might not need one in which case it isn't needed.
Re: Ebike ignition
If your controller's e-lock line is just one cable, then it needs to connect to battery positive in order to "start" the controller. That means one line of the key switch (doesn't matter which one) goes to the battery positive and the other goes to the e-lock line.
This is correct for most controllers, but you should do some research about your controller to eliminate any doubt.
Good luck!
Good luck!
