j bjork
Yes, it may very well be something like that that is causing the problems. It usually happens when braking, the wheel probably locks and moves a little, locks and moves.. There are no faults reported from the controller when it happens.
I think it has happened without braking too, in low or no power. It can happen when I use the regen or just the normal mechanic brake.
I have ruled out the most things I can try by disabling in the program and disconnect everything that is not needed.
Basically the only thing I have left to try is lowering the phase amps and throttle rise/decline. But I think it should show an overcurrent fault if it was something like that :?
I dont have a wheel or hub with any sort of soft mount for the sprocket, I dont know if it exist for a dirt bike.
