w0utje
- Joined
- Jan 12, 2020
- Messages
- 51
famichiki said:mbrusa said:At 25km/h it's acceptable, but below 20 it's a continuous on/off, not what a PID tuning should do.
One other thing, in my own port I had a rare problem of the displayed speed freezing and the motor continuing running by itself at low power as if on cruise or walk. It would happen about once in every 100km of riding and the display speed was never the same. The only way to fix it is to power off. Have you had anything like that happen? I think I was using power assist mode. But I wonder if it's an underlying problem in Buba's code or something I'd done, although he did put a few fail safes into the code.
I've got the same problem sometimes, speedo is stuck at a certain speed and the powerassist is also set at a fixed level and very unresponsive at that moment. Keeps pushing when not moving the paddles. Solved by turning it on and off again. Happens every few 100km's I quess.
