Jordan325ic
- Joined
- Aug 5, 2020
- Messages
- 121
Any mechanical engineers familiar with this sort of shaft dimensioning? What are the extra digits following each nominal dimensions (14 -.03 / -.04, 4 -.01/-.02)?
My hunt to understand brought me to this, which I have found replicated (appears to be ISO 14 splined shaft standard, DIN 5463).
https://roymech.co/Useful_Tables/Keyways/Spline.html
If I am understanding this correctly...
The OD could be: 16.98mm to 16.99mm
The ID could be: 13.96mm to 13.97mm
The tooth could be 3.98 to 3.99mm
So would that same tolerance (in reverse) apply to the sprocket?
