Tommm said:
DtiK said:
1. Is there anyone that has succesfully got Cyclone 3000w working with Grin Phaserunner in sensored mode? What did you do? I have read about doing "RC-filter" to hall sensors to fix their output? Someone enlighten me.
2. Alternatively, is it possible to get Cyclone 3000w to work smoothly from standing stop with sensorless mode?. I am unable to get good settings for that. I get phase overcurrent faults and I'm almost clueless which settings I should I raise and which decrease. One thing is sure that raising Current Regulator Bandwith causes RF interference in my Cycle Analyst speedometer. It reads like 200-300km/h when I try to accelerate, before limiter (99kmh or 25kmh depending on which preset I have) stops my acceleration.
My settings now:
Feedback bandwidth tuning
Current regulator bandwidth: 1050 rads
PLL Bandwidth: 875 rads
PLL Damping: 2,00
Sensorless starting parameters
Alignment Hold Time: 100ms
Autostart Injection Current: 50,1A
Autostart Spinup Time: 3000ms
Autostart Max RPM: 8 RPM
I have cyclone coaxial and asi bac2000. No it doesn't work out of the box, same way it doesn't for kelly controllers either. WIth kelly, it apparently works if you use the halls on 12v instead of 5v (didn't try that with the asi), there was also some pullup resistor mod mentioned on this forum, I did the mod, no change. (phaserunner is made by asi)
I did figure out some killer sensorless settings, so you don't really notice it is in sensorless unless you are attempting to start from a huge incline hill.
12v instead of 5v did not help. doesnt work. no difference.
can you share killer sensorless settings? best i have got with phaserunner is like jumping with kangaroo and successful launch without error codes depends on throttle position (too much throttle = error).
Also, i dont understand why my sequence goes like this when i turn motor by hand:
https://www.youtube.com/watch?v=vcqBYwxCyFo
like it sees "too much yellow".
with other controllers my cyclone runs just fine in sensored mode! must be something strange in phaserunner.. but im not only one having this problem with phaserunner + cyclone.
