jamiejackherer
- Joined
- Jun 11, 2019
- Messages
- 59
larsb said:jamiejackherer said:And bare in mind, I'm running this with a 48V battery, as we should all know, lower volts and higher amps is the way to destroy any motor. If I was running higher volts, say a 60v or 72v and still the same wattage my amps would be lower. It's much harder to get 190 amps through 48v than it is to do the same at 60v..
This is an interesting topic and i think it is not true, at least in a general sense. We are looking at the motor side so there can be some different cases
1) power to the wheel is the same --> doesn't matter what input to controller is. Power to the wheel is torque*RPM and torque depends on phase current, if phase current is the same then motor is driven the same when it comes to losses and heat.
2) motor is stalled and fed same power --> phase current limiting is done, phase current is the same, motor is driven the same
3) Motor is driven but current limiting is not taking place. Controller output corresponds to throttle input. To be able to compare in one use case i guess requested acceleration must be the same --> phase current is the same, motor is driven the same.
Would like to hear what @mxlemming has to say about these lines, if you programmed controller drive routines then this must be a known for you.
jamiejackherer said:Guys, I'm genuinely not interested at this stage in my game to learn everything about motor technology.
I was told that I would never be able to do it. I would fail. I don't know what I'm doing and I need to learn everything first. Was it one of you guys that said winding motors is a fine art? And a skill that not many people can achieve?
Here's an example, my first rewind attempt...
My second attempt...
My third is what you in my pics. A near perfect wind.
My fourth and latest rewind was a success first time... 2 places on the last wind that concernee me, where I only managed to get 2½ turns where everywhere else has 4!!
mxlemming said:This is the first thread I've seen on endless sphere that's turned nasty. And there are subsequently 2 others.
fatty said:mxlemming said:This is the first thread I've seen on endless sphere that's turned nasty. And there are subsequently 2 others.
Perhaps first outright nasty, but I've replied to an increasing number of authors here (though worse on and perhaps influenced by social media?) that posit their own lay interpretation of physics (weight transfer, motor constants and operation, etc), and reject any conflicting proven laws or quantitative data. It seems fake news has become fake facts, and many people have adopted a guiding belief of "factual relativism".
mxlemming said:Try posting your motor here:
https://www.mentalhealthforum.net/forum/
mxlemming said:You don't want to learn, not interested in learning but want good feedback.
mxlemming said:Did you come here hoping we'd all dance around your motor circle jerking? "Oooh Jamie, your windings are so tight, you must have enjoyed tapping that, can you get that fill in my motor?"
Not going to happen here. We're here to learn, understand.
