If you want to see the current continue (time to display =0), it is logical you can't measure odo and speed anymore, because the time is always set to measure current, so there is no time left to capture and process the speed pulses.Hilo said:.....
Now I set only"battery current" data display on VLCD6.
That let me monitor battery current when I am riding at hill......
But I found the ODO meter won't increase anymore, even enable or disable "Odometer compensation".
Elinx said:If you want to see the current continue (time to display =0), it is logical you can't measure odo and speed anymore, because the time is always set to measure current, so there is no time left to capture and process the speed pulses.
This is because there is only one display value (normally speed) which is shared, that is why you must enter a certain display time.
The "always on" possibility is usefull for diagnostic measurements.
If you want more display options you must choose another display like 860C.
I have never heard of the adc torque value that decreases with max weight.Atrihalov said:Hello. I changed the torque sensor to a new one. I now have the display of the sensor value, when you give the full weight, it decreases. Although you can ride. Is it incomprehensible to the bee?
It was true. But today it became normal. Apparently the system has somehow adjusted itself.mbrusa said:I have never heard of the adc torque value that decreases with max weight.Atrihalov said:Hello. I changed the torque sensor to a new one. I now have the display of the sensor value, when you give the full weight, it decreases. Although you can ride. Is it incomprehensible to the bee?
It is probably a hardware calibration problem.
make -f Makefile_windows
sdcc -c -I../common/STM8S_StdPeriph_Lib/inc -I../common -I. -I../ -mstm8 -Ddouble=float --std-c99 --nolospre --out-fmt-ihx --debug -oebike_app.c ebike_app.c
make: *** [ebike_app.rel] Illegal instruction: 4
razm said:Hi !
Thank you for all the great work done here! I was trying to compile version TSDZ2-v20.1C.1-VLCD5-VLCD6-XH18 on my MAC running on big Sur 11.5.2. When executingi get an error on the ebike_app.c compile step - see below:Code:make -f Makefile_windows
Code:sdcc -c -I../common/STM8S_StdPeriph_Lib/inc -I../common -I. -I../ -mstm8 -Ddouble=float --std-c99 --nolospre --out-fmt-ihx --debug -oebike_app.c ebike_app.c make: *** [ebike_app.rel] Illegal instruction: 4
Did anyone hit this issue before? Any tips on a fix for it?
Thank you !
razm said:Hello again!
Now that I have managed to have the firmware flashed and I am very happy with it I am looking for the next upgrade. I have just ordered a new SW102 and the necessary cables. While waiting for the delivery I was checking the where are all the latest firmware and Otaupdates and was not clear wich repositories have what. Can somebody please help with locations/repositories for following?
-latest TSDZ2 firmware
- initial firmware for SW102
- latest OTAupdate for SW102
Thank you!
dameri said:razm said:Hello again!
Thank you!
https://github.com/emmebrusa/TSDZ2-Smart-EBike-860C/releases/tag/v20.1C.3-860C-NEW
Wiki: https://github.com/OpenSourceEBike/...ub.com/emmebrusa/TSDZ2-Smart-EBike-860C/wiki]
You are wellcome.razm said:Thank you dameri!
Thank you!
mbrusa said:On 860C there is no voltage calibration, I'll try to add it to the next version.
