stancecoke
- Joined
- Aug 2, 2017
- Messages
- 1,808
qfade said:I am buying a pressure sensor:
https://pl.aliexpress.com/item/32952233498.html
And I have a beautiful solution.
It can also be used in other MID engines
?! Please show me your solution with photos, if you have integrated this bottom bracket sensor in an existing middrive housing!
The T4 sensor is very fragile, you better would use a T9...
I still don't understand your aim. What do you want with 70 amps in an TSDZ2??? It will glow in a few minutes.... If you manage to bring the heat away, the mechanical parts will be broken within a few days, as they are much to weak for higher torques...
Lishui has a new generation of controllers up to 2kW:qfade said:Which of your Chinese drivers is so small and has 50-70A nominal current?
LD-LS82 - bis 2000W -60V
https://www.pedelecforum.de/forum/index.php?attachments/big-controller-pdf.402866/
regards
stancecoke
