Kevin Orourke 12/2021
Copyright (c) 2021 Ecological Leds LLC. All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions are met:
- Redistributions of source code must retain the above copyright notice,
this list of conditions and the following disclaimer.
- Redistributions in binary form must reproduce the above copyright notice,
this list of conditions and the following disclaimer in the documentation
and/or other materials provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
POSSIBILITY OF SUCH DAMAGE.
This should work on several different eltek psu uints that have i2c,
this is an old protocol from valere. (eltek bought out valere)
HOW TO:
Not always needed, but connect 5v from psu 5v+ pin to arduino 5v+ pin
Connect psu dc out gnd to arduino gnd and psu short pin
Psu sda and scl pins to arduino i2c pins
Psu i2c ground pin to arduino gnd pin, I needed to do this on mine
Comment out what you do not need to set
Note: this is a global command sent to all psu's on the i2c bus
Please, if this works on an eltek psu not listed, please add below to the list
with your name or calltag. Thank you
This works on:
** flatpak2 eltek 48v/3000w HE front end model 480875, 43.5-56vdc 10-60amp -Kevin Orourke
#include <Wire.h>
uint16_t voltage = 4800; // default voltage output in centivolts, i.e. 48.00v == 4800
// uint16_t amp = 6000; // default amps max output in centivolts
// uint16_t vsd = 5200; // default max voltage shutdown in centivolts
void setup() {
Wire.begin();
Wire.setClock(20000);
Serial.begin(115200);
Serial.println("Waiting 15 seconds for PSU");
delay(15000);
scan_i2c (); // check for power supplies on the i2c bus
delayMicroseconds(10000);
commandPsu(0x00, 0x02, 0x72, voltage);// i2c command for setting voltage
// commandPsu(0x00, 0x02, 0x74, amp); // i2c command for setting max amps
// commandPsu(0x00, 0x02, 0x76, vsd); // i2c command for setting max voltage shutdown
Serial.println("done");
Serial.println("better way: disconnect short pin for 2 seconds then reconnect");
Serial.println("other way: unplug power supply and wait 30 seconds");
void scan_i2c () {
byte error, address;
int nDevices = 0;
Serial.println("Scanning for power supplies");
for (address = 1; address < 127; address++ ) {
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0) {
Serial.print("Power supply found at address 0x");
if (address < 16){
Serial.print("0");
Serial.println(address, HEX);
nDevices++;
if (error == 4) {
Serial.print("Power supply error at address 0x");
if (address < 16){
Serial.print("0");
if (nDevices == 0) {
Serial.println("No power supplies found");
Serial.println("Hualting, fix i2c problem");
while(1);
} else {
Serial.println("Setting default voltage");
uint8_t crc82(uint8_t *p, uint8_t len) {
byte chk = 0;
for ( int i = 0; i < len; i++) {
chk += p[i];
chk = 256 - chk;
return chk;
void commandPsu(uint8_t addr, uint8_t p, uint8_t o, uint16_t value) {
uint8_t h = value >> 8;
uint8_t l = value & 0xFF;
uint8_t data[] = {addr, p, o, h, l};
uint8_t crc = crc82(data, sizeof(data));
Wire.beginTransmission(addr);
Wire.write(p);
Wire.write(o);
Wire.write(l);
Wire.write(h);
Wire.write(crc);
void loop() {
