Can anyone tell me, if the QS138 70H motor has got a temperature sensor, and if yes, which one?
When mine arrived from QS (bought it ~1 year ago) , they said they had matched the motor to the controller already,
and when I had a look at the settings, the motor sensor was set to "0" (= no sensor).
In the Kelly KLS settings, there are 3 options to choose from:
"0" for "no sensor"
"1" for "KTY84-130"
"2" for "KTY83-122"
As I said, when it arrived it was set to "0".
When I tried setting it to "1", the "monitor" function of the Kelly controller software showed unrealistic high values.
When I set it to "2", the monitor function shows values which could be correct.
But with this setting the controller sometimes stops working because of high motor temperature.
The "max temp" setting is at 130°C, and when I measure the temperature at the outside of the motor, is is never higher than 70°C. So I am suspecting that this temp.sensor setting is nonsense.
