2x Brand New RG4850G2 3000W Rectifiers - Nucular Chargers
Darren2018
I have already modded these internally so they will switch on without any extra solder joints on the external PCB. Both units are brand new and have only been opened so the modification could be added. I also have the CAN modules to adjust the voltage and current if you need those. If you want these I can do the modification for you without you needing an additional power supply. All the details regarding the CAN modules and modifications can be found here: https://endless-sphere.com/forums/viewtopic.php?f=14&t=86038
If you want to use these for charging via a Nucular controller then you will only need the CAN module if your battery voltage is lower than 53.5V.
Unmodded default spec DC 53.5V 56A @ AC 230V
CAN adjustment DC 41.5V-58.5V 3000W max - 0.1 steps for volts and amps. You can charge from 36V-58.5V with the CAN module.
R4850G2 £80 each
CAN voltage and current module £15 each
P&P £8 UK only
Hello Daren
I m interested by can module
Is it this kind of module?
Are they still available?
Regards laurent
