Thanks for the endorsements guys!
Yeah, still building packs for those located in Australia.
Flick me a PM if interested.
Cheers
Cheers
Cowardlyduck said:Thanks for the endorsements guys!
Cheers
AAAAQQQ said:Cowardlyduck said:Thanks for the endorsements guys!
Cheers
What kind of tests can we personally do to figure out if our battery is in poor health or in need of repair/replacement?
Yeah as TV said check the voltage, but specifically check it's sag under load.AAAAQQQ said:What kind of tests can we personally do to figure out if our battery is in poor health or in need of repair/replacement?
PRW said:I didn't realise - SEB is now making a range of city, gravel, trekking and kids bikes?
https://stealthelectricbikes.com/cb.html#slider1-1h
c_bike.pdf
xtrm_bike.pdf
Stealthlife said:I have a 2022 stealth f37 it has h series crystalyte Motor and controller I would like to hook A12F nuclear up to this could anybody walk me through it
Theodore Voltaire said:You got a big damn cell phone
Stealthlife said:I have a 2022 stealth F37 and it's 72 V and wow what a powerhouse over the old version if you guys want the controller motor specs let me know I also have a YouTube channel called stealth life I cover a lot of stuff if you want to check it out
Rix said:AAAAQQQ said:Anyone with the FOX 40 forks? Did my first full day on the thing, pavement, jumping kerbs and steps, bit of gravel and rocky stuff 100% BATT to 5%. Had the stock forks dialed per my weight but ultimately end of the day, the thing spilled its guts. Was prob due for an overhaul in hindsight.
I do intend to take it on harder off-road stuff in the future, so grabbing something more substantial would be of benefit.
I typically try to buy once and cry once. So my question there's a 27.5" and a 29" option. Being 24" stock front Im guessing no issues with plug and play? And prob should go 29" fork for option to change?
Keep in mind that long travel 29" forks typically have a longer axle to crown ratio then there 26/27.5 counterpart. I only bring this up as it can negatively affect your geometry. But as long as the fork has a 20mmx110mm axle, and a 1.125" fork tube, any fork can be put on your Bomber and your wheel will fit.
Rix said:Do speed run and tuck in behind the screen, I bet you add 3MPH or more onto your top speed.
Theodore Voltaire said:Rix said:Do speed run and tuck in behind the screen, I bet you add 3MPH or more onto your top speed.
I haven't really felt like testing this theory lately because winter weather conditions haven't been ideal. I was thinking I would probably lose a few mph though, but looks like you may be on the right track. Yesterday I jumped out in front of some oncoming traffic, and had to gas it. I was doing over 50 mph in less than a block, big fat ass and all. Right now if I had to guess I'd say this barn door isn't hurting acceleration, or top speed, and probably helps a little. I wasn't laying down either, just sitting in normal riding position like always.
It'll be coming off in another month or so anyway, because it's usually to hot around here for a windshield.
Cozen89 said:Stealthlife said:I have a 2022 stealth F37 and it's 72 V and wow what a powerhouse over the old version if you guys want the controller motor specs let me know I also have a YouTube channel called stealth life I cover a lot of stuff if you want to check it out
The 2022 f37’s are 72v now? You sure about this? I might upgrade if this is true.
Theodore Voltaire said:PRW said:I didn't realise - SEB is now making a range of city, gravel, trekking and kids bikes?
c_bike.pdf
xtrm_bike.pdf
WTF Stealth says on their website a Bomber weighs 148 frickin lbs (67 kg).
