gunthn, no, my nuvinci stays put so far. If your chainline is not quite right it will pull and force things to flex leading to problems, a straight chainline is important imo..
Update on RC bike, you know some days how any project you tackle just works out easily and successfully ?.. well today is not one of those days. :?
Recent problem has been motor/chainring stage rubbing the frame at the swingarm, after a few hard runs parts are bedding in ( cranks onto bottom bracket ) and the 1mm gap i had for the chain is not that wide anymore.. so i got a new slimmer chain, shimano, break the half link chain off, put shimano on and of course.. not a half link it's either one link too long and my tensioner won't work, or too short and can't be connected... grrrr..
Then i decide to swap the 18t ENO for a 16t to reduce the gearing even more, uhm, that aluminum adapter is really.. and i mean " REALLY " wedged in there... I 1st clamped it in a vice, and tried the pin and hammer method, i managed to mangle some metal pretty good..
Then i fabbed up a tool from a 30mm socket ( had to file it down some more, this was made to remove the swingarm on my Honda 250SX trike as the stock honda tool is like 300 $ ), used a big 3/8" bolt and cranked down the set screws, clamped the bolt in a vice..
