This sounds dangerous....or can it done safely?
ebike11   1 MW
Post by ebike11 » Nov 29 2020 12:39pm
Hi guys..space is very tight in my triangle space of my eeb frame with all the wiring..bms and battery packs. I also have 2 x step down voltage units. They arent that big but would removing them from their casings and wrapping them be a bad idea? Trying to free up space here and there but not if its gonna be too risky.
I have 2 of them coz i have them wired to a bunch of different 12V accessories etc.
Thanks!!!
Chalo   100 GW
Re: This sounds dangerous....or can it done safely?
Post by Chalo » Nov 29 2020 2:19pm
Do you know how warm they get when in use? Aluminum housings for components like that are usually heat sinks. If you take away the heat sinks, you'll have to give the waste heat another way out. But if they don't get very warm in operation, it might not be a problem.
999zip999   100 GW
Post by 999zip999 » Nov 29 2020 4:24pm
More info what battery ?
markz   100 GW
Post by markz » Nov 29 2020 6:07pm
A picture on the triangle and dcdc/alum housing would be grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrreat (my tony the tiger impression, though the esso tiger is a better tiger overall, thats for you leisesturm ;) )
