Full suspension BBSHD Trek Build
Show off your Ebike creation here.
DrunkWeldingCompany   100 µW
100 µW
Post by DrunkWeldingCompany » Jan 18 2022 12:32pm
I have always wanted a full suspension ebike. Looking at the prices here in Norway I soon decided to build one myself. Started off with buying this used Trek EX9 2010 model.
Trek sykkel.jpg (685.87 KiB) Viewed 603 times
I was thinking this would be easy. I soon discovered that this bike not was the easiest converting with the small triangle frame and the shimano pressfit bb71 bottom bracket. Started off designing a battery that would work for the bike. Finally made something work. My next post will be on this subject.
100 µW
The Battery
Post by DrunkWeldingCompany » Jan 18 2022 1:26pm
To run BBHD at around 1000W I decided to go for a 13S5P configuration using salvaged LG MH1 3200mAh cells. This would give me an OK capasity of around 15Ah. The cells are also rated for 10A max, therefore they should easily handle the 20-30 Amps the controller would pull at 48V. The first problem I encountered was finding a box (or premade battery) that would fit the small triangle with the suspension taking away a fifth of the area. I soon gave up and dusted off up my old Freecad skills. Ended up with theese:
18650 mount.jpg (111.01 KiB) Viewed 595 times
I am posting the STL-files on thingiverse. Just havent got around to it yet. Send me a pm if you want the .STL or the Freecad files if you would like to print one or edit it yourself.
100 µW
Re: Full suspension BBSHD Trek Build
Post by DrunkWeldingCompany » Jan 18 2022 2:14pm
Got it pieced together. Pretty pleased with it so far. Still waiting for the 0.2x8mm nickel strips from ebay to complete it. Really hope they dont turn out to be nickel plated steel.
Also bought this BMS:
https://www.ebay.com/itm/254484111612
Anyone has any experiences with theese? I know the price is a bit on the low side to get good quality, but Ill just cross my fingers and hope it doesnt trash my battery. Guess well see soon ;)
100 µW
Post by DrunkWeldingCompany » Jan 20 2022 7:17pm
Finally got the box uploaded to thingiverse if anyone wants it.
https://www.thingiverse.com/thing:5205983
Having some problems with the alignment of the chain and the general fit with the adapter for the bottom bracket. Ill make a post about it tomorrow.
100 µW
Alignment
Post by DrunkWeldingCompany » Jan 21 2022 6:56pm
Found this template for the BBSHD from ebike essentials:
https://cdn.shopify.com/s/files/1/0537/ ... 1619116147
I have some questions I hope one of you guys can fill me in on: Are there really 2 different offsets as the template shows between different chainrings? I have to go for the inner one to make up for seemingly bad alignment. Does this mean I cant go for anything smaller than the inner 42T? Guess I also need to shave off some metal from the bottom bracket as I have about 10mm of play before I hit the chainstay.
100 µW
Mounting up the battery box
Post by DrunkWeldingCompany » Jan 25 2022 5:54pm
Got around to mounting the battery box today. I used one of the original rivnuts for the bottle bracket and added two more into the frame. Next I secured it to the frame using a flat aluminium bar with three countersunk bolts. There is also a hole in the top of the casing for a strap or zip tie to the top bar. This ended up being really rigid and solid. Dont think I will have any problems with it coming loose. Fingers crossed ;)
LewTwo   1 MW
Post by LewTwo » Jan 26 2022 1:34am
Neat job on the battery box. What type of filament did you use to print it?
The more I learn the more obvious the immensity of my ignorance becomes.
Weight Wennie E-Bike https://endless-sphere.com/forums/viewt ... 3#p1173723
Shaft Drive Grocery Getter https://endless-sphere.com/forums/viewt ... =6&t=90718
...and thanks to Justin!
100 µW
Post by DrunkWeldingCompany » Jan 26 2022 5:01am
Thanks. I printed it in PLA. My only possible concern is temperature. Pulling 30Amps from the battery in the summertime, the temperature might be a problem as PLA turn soft at about 80-100Celsius, but I think it will be ok. If this turns out to be a problem, Ill just print it again in PETG. Used PETG for the lid, but had some issues with warping when printing the box, so ended up using PLA for it.
LewTwo   1 MW
Post by LewTwo » Jan 26 2022 5:28am
PLA was intended to be biodegradable. It will eventually deteriorate ... but must faster if exposed to UV (aka the sun). You might want to spray is with with something that is UV resistant (urethane spar varnish for example).
100 µW
Post by DrunkWeldingCompany » Jan 26 2022 5:46am
Thanks for the tip. I will try to get the printer better tuned so that I can print it in PETG. I also see that PLA degrades when exposed to rapid changing temperatures, so printing in PETG will be a priority.
