Votol em70
Xray8700   1 µW
Votol em70
Post by Xray8700 » Jan 26 2022 2:49pm
Unlock speed limit.
I have this electric "tuk tuk" with a qs midt drive motor 2000w and votol em 70. 60v battery
It stops at 30 kmh..
Can anyone please help me out, I have the cable and software, but I have absolutely no idea what settings I need to change. 👀😔
amberwolf   100 GW
Re: Votol em70
Post by amberwolf » Jan 26 2022 6:38pm
Does the powered wheel spin the same max speed when it is propped up off ground?
If so, there's a speed limiter.
If it is faster, then there's no speed limiter, just not enough power for what you want, or the gearing is too low for the speed you want, or the voltage of the system is too low to spin the motor fast enough.
I don't know the Votol software, but there are some Votol threads on the forum discussing it, if you poke around; they may help with that part.
If you found this advice helpful, supporting contributions are accepted here.
Beginning of a New Life
Give a listen to my music!
(More here, including experimental)
