My diy electric longboard so far, parts list sk3 213kv
PracticalProjects   10 W
Post by PracticalProjects » Aug 06 2013 3:23pm
Hello everyone. After searching through the forums i have come across some very useful information and some very helpful people. To all the contributors of this site I thank you for your help! Anyway so after quite a long time and lots of planning I think I have finally chosen the parts for my board. Any feedback or suggestions will be much appreciated.
So I thought that i would start by building my own board, I glued 4 sheets of ply together and put it into my home build longboard press. Not taken it out yet so I hope it turns out well. I got some holey trucks, mini logo bearings and some rather nice Cadillac wheels which should be fairly smooth . This is a picture of it in progress
In the press
Trucks and that
Right so on to the electronics. The basics i gathered from the forums is a low kv motor, reasonably high discharge battery and preferably more ma/h for range
The motor i think I'm going to use was what i thought would be a good middle between the higher speed ntm prop drive 270kv motor that is commonly used and the low 170 kv higher power motor that is sometimes used. I thought that this would also be a good middle in terms of speed and battery life. so it is an unbranded 230kv 63mm motor, please let me know your thoughts on this - http://www.giantshark.co.uk/n636409kv23 ... 07740.html
For the esc i wanted to get something that is good quality to avoid having to purchase another in the future. I went for the hobbywing xerun 150a - http://www.giantshark.co.uk/xerun150asd ... 05858.html this has some great features and programming options, I will get the programming card for this
The battery decision is where i've gone round in circles, I went over several lipo's then onto LiFiPo4 on account of them being more tolerant to several aspects that may come about on an ev. I think i'm going to get 18 cells of nimh as they are easier to charge and don't require as much effort in my oppinion. However i'm still unsure whether this will work as well as i hope. Any advice will be much appreciated. But i'm thinking 3 these in series - http://www.overlander.co.uk/batteries-c ... sport.html
For the controller i was going to get a flysky transmitter and reciever for rc car - http://www.giantshark.co.uk/flysky-gt3b ... 07574.html
To actually make this thing move i will either make my own motor mont or order a nicely designed and machined one from Richard at Alien Drive systems. I am thinking of going for chain drive in a ratio of 12t to 32t. I thought that this would be a safer option as the area near me has some relatively steep hills, again thoughts on this will help.
Right so I think that's about it, i'll be glad if you enjoyed reading that and as I said any suggestions will be welcome.
Thanks
torqueboards   100 MW
Re: New project, choosing the parts for my diy Longboard
Post by torqueboards » Aug 06 2013 5:24pm
The 63mm motors are good and should work well. 50mm I don't think is too bad either. Both give a decent amount of power. I've been riding (1) 63mm but have a dual 63mm setup. My (1) 63mm does pretty well even uphill. I've also heard good things about the Xerun 150A ESCs too. I find my Lipos to work fine. I'm using 2x 5S 8000mah in series.
I'd like to make my controller smaller. I'm using a similar one but the orange HK one. If you have any experience with ripping it apart let me know. I'd like to make a plastic case for a smaller one.
I'm working on making my own motor mount. I already have it designed just need to tweak it and test it and it will be much cheaper than the current alternatives currently if you are interested. I do like the custom metal builds and being welded on. Those are definitely a strong and sturdy mount.
Keep it up with your build. I would like to see more.
DIYElectricSkateboard.com Electric Skateboard Kits
Post by PracticalProjects » Aug 08 2013 3:21pm
Thanks very much on second thoughts i think I may go for the NTM Prop Drive 270kv which is 2400w of power i believe, do you think that this will be enough power if I set up the esc properly and with the right gear ratios to take an average sized man up a small incline? I think if so that's what I'm going to get. Yeah I am going to try and reduce the size of the remote if I can and lazer cut a case for it, main thing is that they use 8 aa batteries which can easily be replaced with a lipo so I think it will be possible. I'm planning to make my own mount now as well, ill make a design when I get the motor and belts and that. Thanks for responding and thanks I will post the progress of my build to the forum :)
torqueboards   100 MW
Post by torqueboards » Aug 08 2013 3:42pm
Yeah I'd go with the 50mm NTM 270kv, might as well. Nice, post details when you break down that controller. I'd like to see it. What 8AA lipo would you use to replace it?
Post by PracticalProjects » Aug 09 2013 4:55pm
ahh yeah, thanks for agreeing, I will do, might get this 9.9v LiFePo pack http://www.hobbyking.com/hobbyking/stor ... pack_.html but ill have to check things first
Post by PracticalProjects » Aug 11 2013 11:35am
Progress on my longboard
Out of the press
SAM_0723 forum.JPG (40.34 KiB) Viewed 10316 times
Cut out with first coat of varnish
IMG_2667 forum.JPG (40.75 KiB) Viewed 10316 times
torqueboards   100 MW
Post by torqueboards » Aug 11 2013 2:35pm
Nice. Lol I wish I had all those tools. How did you acquire all your tools? What did you use?
Post by PracticalProjects » Aug 11 2013 3:40pm
Just a few of my dad's collection of tools in the garage :) we used some scrap wood, 10mm threaded rods and nuts and a drill to make the press. Then the shape was just marked out and cut with a jigsaw with a fine toothed blade to give a nice clean cut. Then just a file and various grades of sandpaper to finish it off, then we are putting about 4 coats of clear yacht varnish to protect it + make it look nice :)
torqueboards   100 MW
Post by torqueboards » Aug 11 2013 3:49pm
Pretty nice. Looks very symmetrical too.
furp   100 W
Post by furp » Aug 11 2013 5:07pm
Looks really great! Gotta build one myself once my deck is beaten up. What kind of wood and glue did you exacly use? Doenst look like the ply wood I had in mind.
Post by PracticalProjects » Aug 12 2013 2:43am
Thank you both of you! the glue was evo-stik resin weather proof wood adhesive for exterior, apparently dries stronger than wood itself! Yeah its not the standard ply a lot of people use, it was just a sheet that looked quite nice and it was the only decent ply they had at the hardware store near us, I hope it holds up well, seems strong enough.
Post by PracticalProjects » Aug 15 2013 1:28pm
Finished the board! rides really well. Electronics on the way!
lone_deranger   100 mW
Post by lone_deranger » Aug 15 2013 1:59pm
Nice, looks like you've included a touch of rocker. Should help when the force is with you.
Post by PracticalProjects » Aug 15 2013 2:32pm
Thank you, just a little yeah
Re: My diy electric longboard so far, parts list
Post by PracticalProjects » Aug 19 2013 7:52am
I got my first lot of parts in the mail today. In the end I went for a Turnigy aerodrive 213kv motor, K-force HV esc and 2 5000mah 4S lipo's to beconnected in series (silll awaiting the other battery) :D
Motor
esc
Motor
There is more info and a more detailed look of these parts on my website.
Thanks for all your help on this forum, I am finally underway!
Murfix   100 W
Post by Murfix » Aug 19 2013 7:57am
Looking swell :) What's your website?
*NVM, found it on your profile page
Memo to myself: Screw it, just do it!
1 Apr 2013 - Start pre-engineering my first EV build!
6 Aug 2013 - Ordered all parts for my Emtb 8s 2x2kW 270kv Alien ESC setup.
3 Sept 2013 - All parts have arrived: on to the build!
23 Sept 2013 - First test ride: AWESOME!
7 Feb 2014 - Upgrade finished: 3kW motors, 12S Alien ESC, entire new drivetrain and LED's!
Build topic: http://endless-sphere.com/forums/viewto ... 35&t=52390
Post by PracticalProjects » Aug 19 2013 8:02am
Thanks :) ahh ok, there's also a little button underneath my profile picture on every post
torqueboards   100 MW
Post by torqueboards » Aug 19 2013 11:59am
Does that ESC you have, have any brakes? Have you tried riding your board yet?
Post by PracticalProjects » Aug 19 2013 12:39pm
yeah it has, you can set it to off/soft/hard/very hard with a default of off. Looks pretty good so far. I haven't built the board yet, just awaiting a couple of parts before I can finish it. I'll have to do a bit of testing before I can recommend this esc to anyone. I hope it will be ok. I'll keep you posted.
dirkdiggler   10 kW
Post by dirkdiggler » Aug 19 2013 12:48pm
Is that the 70a HV esc opto? I am curious how you power your reciever and how well the brakes work with it. Hope it works well, thats what I want to try next. I want to up the voltage and decrease the size of the esc. I am thinking of using a boat esc for the brake option and it is sbec.
Post by PracticalProjects » Aug 19 2013 2:36pm
dirkdiggler wrote:Is that the 70a HV esc opto? I am curious how you power your reciever and how well the brakes work with it. Hope it works well, thats what I want to try next. I want to up the voltage and decrease the size of the esc. I am thinking of using a boat esc for the brake option and it is sbec.
Hi, Its the 120a version, i'll be powering my reciever with a seperate nimh pack, I haven't tried it yet but I will post it on here when I do, should be up and running in about a week, hopefully.
torqueboards   100 MW
Post by torqueboards » Aug 19 2013 10:58pm
I think that's a heli/airplane ESC. I'd like to know how well the brakes work on that. Let me know when you get a chance to try it. There's a lot of high voltage ESCs I'd like to try if we can use them for eboards.
Post by PracticalProjects » Aug 20 2013 3:40am
It is, I'm also looking forward to trying it, I hope it all works ok, I'll let you know
Post by PracticalProjects » Aug 24 2013 5:14pm
The rest of the parts arrived, I mounted the motor
The parts
Motor
torqueboards   100 MW
Post by torqueboards » Aug 24 2013 7:00pm
Sweet should be fun once it's up and running. Have you ridden one before?
