Power calculator
A place to list links to sources for EV related parts and services.
Miles   100 GW
Post by Miles » Jun 30 2007 5:03am
Version 3 attached.
The expressions used for the formula in cell G7 were revised to enable the spreadsheet to function correctly on Google Spreadsheets.
You can now use this calculator without the need for Microsoft Excel.
Create an account with Google and upload the file to http://docs.google.com/
Please post any bugs/suggestions here.
Miles
P.S. I'm intending to append a table of "typical values" to the spreadsheet, so that people will be able to enter the value that most closely corresponds to their specific case.
Ebike powercalc rev. 3.zip
(6.02 KiB) Downloaded 1058 times
Miles   100 GW
Post by Miles » Sep 05 2007 9:49am
If you don't have spreadsheet software, you can also upload this program to: http://www.editgrid.com/site and use it online. Editgrid seems to be better than Google Docs.
PJD   100 W
Post by PJD » Nov 01 2007 10:07pm
As far as power calculations for climbing various grades, a while back I set up a spreadsheet so I could use the various slope hills in my area, along with a drag force calculation as a sort of poor-boy dynamometer test.
The spreadsheet is attached. It provided actual motor performance graphs for a hub-motored bike, or it could be modified easily for a chain or reduction gear.
It gives the calculation results and both metric and US units, but the raw data has to be in US units, sorry.
The numbers entered on it representing the actual performance on my e-max.
fechter   100 GW
Post by fechter » Nov 02 2007 9:02am
Whoa.. almost 5kw. That's a pretty spunky scooter.
deardancer3   10 kW
Post by deardancer3 » Dec 09 2007 11:57am
I like this power calculator; thought I would share.
(It lets you easily swap out different bike frames with default setting)
http://www.kreuzotter.de/english/espeed.htm
Dick in colorado
paultrafalgar   10 kW
Re:
Post by paultrafalgar » Jun 11 2008 6:40am
PJD wrote:As far as power calculations for climbing various grades, a while back I set up a spreadsheet so I could use the various slope hills in my area, along with a drag force calculation as a sort of poor-boy dynamometer test.
That's a fascinating spreadsheet, PJD. What I find interesting is comparing Row 12 with Row 16.
You have halved (approx) the speed and EVEN though it's doubled the slope, you use 60% of the power!!!
SLOWING DOWN ON THE CLIMB is the way to go.
If we knew what it was we were doing, it would not be called research, would it? Albert Einstein
A paranoid is someone who has SOME idea of what's going on. Allen Ginsberg(?)
If the greatest pleasure is giving, be selfish - give pleasure.
Miles   100 GW
Re: Re:
Post by Miles » Jun 11 2008 6:52am
paultrafalgar wrote: SLOWING DOWN ON THE CLIMB is the way to go.
Slowing down makes very little difference to the total energy consumed to climb hills.....
paultrafalgar   10 kW
Re: Power calculator
Post by paultrafalgar » Jun 11 2008 7:05am
Not according to PJD's spreadsheet.
paultrafalgar   10 kW
Re:
Post by paultrafalgar » Jun 11 2008 7:09am
Miles wrote:If you don't have spreadsheet software, you can also upload this program to: http://www.editgrid.com/site and use it online. Editgrid seems to be better than Google Docs.
Just a little plug for OpenOffice. You don't need to be without a spreadsheet! OpenOffice is FREE for both Windows and Linux (probably Mac as well, I don't know).
IMHO better than Microsoft Excel by far.
:D
Miles   100 GW
Post by Miles » Jun 11 2008 7:14am
If you halve your speed you take twice as long to climb the hill.....
Sure, we know the power required to overcome air resistance goes up with the cube of the speed but if the power required to climb goes up linearly then slowing down on hills will have less effect on the total energy consumed than it would on the flat.
Miles   100 GW
Re: Re:
Post by Miles » Jun 11 2008 7:16am
:D
I certainly wouldn't disagree with this :D
I moved from Excel '98 to Open Office Calc after trying Microsofts' latest.......
Miles   100 GW
Post by Miles » May 13 2009 12:31pm
Latest version, in ODS format:
Ebike powercalc Rev. 4.ods
(25.32 KiB) Downloaded 833 times
Eric   10 mW
Post by Eric » May 21 2009 8:27pm
Am I the only one who cannot open this due to its password protection? It probably works fine in other spreadsheets, but Xcel is having issues.
Eric
paultrafalgar   10 kW
Post by paultrafalgar » May 22 2009 3:15am
Eric wrote:Am I the only one who cannot open this due to its password protection? It probably works fine in other spreadsheets, but Xcel is having issues.
Eric
It's an open-source format that OpenOffice uses, I'm not sure if Microsoft recognises/tolerates importation of .ods, but if you ask Miles nicely, he will convert it using Openoffice to Microsoft .xls format! BTW IMHO Openoffice calc is vastly superior to Excel and it's a free download, so why not get a copy that runs on Winders (if you must use a c**p operating system. :D )
Miles   100 GW
Post by Miles » May 22 2009 4:26am
Hi Eric,
Here's an older version in Excel format and a conversion of the latest from .ods to .xls:
Ebike powercalc Development Excel.xls
(83 KiB) Downloaded 849 times
Ebike powercalc Development1 Excel.xls
(24.5 KiB) Downloaded 1054 times
Miles   100 GW
Post by Miles » Sep 14 2010 1:37am
Revision 5.
- Added breakdown of torque at the wheel.
- Altered background colours of cells.
Ebike powercalc rev.5.ods
(25.53 KiB) Downloaded 510 times
Miles   100 GW
Post by Miles » Sep 14 2010 8:27am
Revision 6. Simplified version.
- Removed battery characteristics; motor efficiency and torque inputs.
- Removed distance and amps outputs
- Added motor torque output.
OpenOffice format (for Excel format see 2 posts down).
Ebike Powercalc Rev. 6.ods
(21.5 KiB) Downloaded 958 times
Miles   100 GW
Post by Miles » Sep 21 2010 7:53am
Miles   100 GW
Post by Miles » Sep 21 2010 7:57am
Revision 6 as an Excel file:
Ebike Powercalc Rev. 6 (Excel).xls
(24.5 KiB) Downloaded 1010 times
Miles   100 GW
Post by Miles » Jul 17 2011 5:16pm
Good reference for rim/tyre sizes:
http://www.ctc.org.uk/DesktopDefault.aspx?TabID=3802
crossbreak   100 MW
Post by crossbreak » Aug 08 2013 8:54am
thx so much, we should develop this further and add a motor simulator like PeakEff. Then we would have something like the ebikes.ca/simulator as stand alone Excel software :)
Miles   100 GW
Post by Miles » Aug 19 2013 2:01am
Feel free to take it in any direction you like CB.. :)
I thought that this would be more useful to others than, in practice, it has been... For most people, the Kreuzotter calculator seems to be sufficient.
crossbreak   100 MW
Post by crossbreak » Aug 19 2013 8:37pm
wasn't aware of this one.. use my own Matlab simulink Simulation which can do something with motor resistance, e-rpm, inductance and so on.... i like the ebikes.ca simulator for the variety of different motors. It's just not sufficient to input "Watts" if a motor is involved IMO. The ebikes.ca simulator shows this very good, but does not take eddy current etc into account. When my Simulink stuff is perfect i'll try to do something similar with Excel
Miles   100 GW
Post by Miles » Jan 16 2014 1:08am
made_in_the_alps_legacy   10 kW
Post by made_in_the_alps_legacy » Jan 16 2014 1:15am
From a very good doc
The Aerodynamics of Human-Powered Land Vehicles
Albert Gross Chester Kyle Douglas Malewicki
Read the complete doc HERE
Pay attention to the chart on page 6 :
Last edited by made_in_the_alps_legacy on Jan 16 2014 1:59am, edited 1 time in total.
