Strong GT-S
recumpence   100 GW
Location: On Earth right now. That can change at any time, though..........
Strong GT-S
Post by recumpence » May 03 2017 5:44am
Hey Guys,
A friend of mine in Quebec bought a Strong GT-S 210 (never heard of it before). Do any of you guys have info on this bike? One primary question I have is replacement (upgraded) battery for it. He hates the heavy SLAs it has. Anyone have advice on a somewhat drop in lithium pack for it? I am too far away to give him a hand with it, but he is mechanically inclined and not scared of a little work to improve this thing.
Any advice would be appreciated.
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
marcelo56   10 mW
Re: Strong GT-S
Post by marcelo56 » May 03 2017 8:20am
whereswally606   100 kW
Re: Strong GT-S
Post by whereswally606 » May 03 2017 8:46am
es users: Brentis and mushymelon used them in builds before. I have one in my loft which I plan to convert when I get a round tuit. I think welding up extra gussets would be smart if going for high power.
Distributing "Lebowski" FOC Controller PCB (Through hole) since 2016
Moped: Emax 110s 2009
MadRhino   100 GW
Re: Strong GT-S
Post by MadRhino » May 03 2017 9:29am
It is pretty old. One of the first ebikes to be sold here. Very heavy frame, with tubing enclosing the battery box. Some had "Mag" wheels. A modern battery fitting the mounts would need to be custom made, but there is plenty of room and it is easy to adapt almost any commercial battery. I have seen a few, long time ago. I never considered building with this frame because of weight and lack of suspension.
spinningmagnets   100 GW
Re: Strong GT-S
Post by spinningmagnets » May 03 2017 10:41am
I really like that frame for an ebike, needs lithium battery conversion from SLA...
markz   100 GW
Re: Strong GT-S
Post by markz » May 07 2017 7:40pm
I have one of these bikes, it was sold by Canadian Tire, 350W geared motor, and lead acid batteries, I think 36V, because there were 3 of them. I burnt out the brushes on the motor in no time, planned on replacing the brushes but the motor stunk too bad so I just threw it out.
You can use any 36V chemistry you wish, I used LiPo when I got mine. I paid $200 for mine, it had dead batteries.
I will see what pictures I have on my desktop to slap up here for you.
Its an all steel frame, has 165mm rear drop out spacing.
165mm spacing.jpg (307.28 KiB) Viewed 2986 times
wasp   10 kW
Re: Strong GT-S
Post by wasp » Aug 25 2017 10:34pm
just bought one of these also for 50 bucks and i really like it
something about full suspension all steal extended wheelbase
very good battery setup...ect
looking forward to a winter build with this and a monkey faction
wasp
markz   100 GW
Re: Strong GT-S
Post by markz » Aug 25 2017 10:40pm
Great deal on the frame, $50 cant go wrong.
If you got a welder, beef up the top shock mount.
Mine broke off, I posted a picture of it in another thread.
viewtopic.php?f=6&t=46993&p=1313448&hil ... t#p1313448
I am now riding my Townie 21D, way different riding position between the two. Townie is more stretch out, GTS is more upright. I'm keep my GTS but am waiting for a good deal on a 225+A stick welder in the classifieds. I may rent one too from Hertz Equipment Rental, but I find I can always find a need for a 225A welder if its $100 or $150 used.
wasp   10 kW
Re: Strong GT-S
Post by wasp » Aug 31 2017 6:32pm
any idea on the pivot point bushing replacement on these frames?
mines got play and would like to replace or improve it any idea's
thx wasp
Voltron   100 MW
Re: Strong GT-S
Post by Voltron » Aug 31 2017 6:43pm
I read about a couple that cracked in the middle where the upper end of the shock attaches... but they seemed ridden pretty hard.
wasp   10 kW
Re: Strong GT-S
Post by wasp » Aug 31 2017 7:56pm
Voltron wrote:I read about a couple that cracked in the middle where the upper end of the shock attaches... but they seemed ridden pretty hard.
i plan to ride this as hard as the others...
i will add a second tube there and reweld shock support
i like this frame and with no tire on the rear swingarm already sits at 175-180
would like to go 2x mac motors and a good range of battery
wasp
Ypedal   100 GW
Re: Strong GT-S
Post by Ypedal » Aug 31 2017 9:00pm
got one rotting away behind my garage.... horrible machine .........
ES site status page:
