Troubleshooting Kelly controller
pks   100 µW
100 µW
Post by pks » Jun 03 2018 10:56am
Hello,
I was hoping if somebody can help me understand what is going on with my Kelly KLS7218S controller. It was running fine for a couple of days after I've completed the build, however yesterday I've decided to reroute some wiring and having completed the reroute the controller now throws Hall Sensor error and fails to run. I've traced all wires, they seem to be intact. No connector changes or any other obvious wire damage.
I've started testing voltage and noticed something strange. With motor fully disconnected the hall sensors pins (16,17,18) from the controller measure ~12v all the time. Is this is an expected behavior for the controller?
eee291   10 kW
Re: Troubleshooting Kelly controller
Post by eee291 » Jun 03 2018 2:11pm
No, I'm pretty sure Kelly uses 5V on the halls.
Try unplugging all three connectors,try routing Battery Pack B+ voltage to pin7(ignition) which looks like a light pink color.
Then try measuring The Black(21) and the Purple(5) on the Motor Hall Plug.
If it's back to 5v connect the Halls back to the Motor, then connect your phone or Pc to it and check the info tab where you read the Hall error. In the middle column you can see Hall A,B and C. Then try turning the Motor by Hand to see if all the fields have changing values like 0 and 1 at one point or another. This is to check the Motor Halls for any damage or broken/pulled wires.
Now if the controllers Hall voltage didn't drop down to 5V you might have a broken Controller. I once had a badly soldered EC5 Battery connector on my controller which came loose caused a spark gap. when accelerating it would spark like 50 times a second which killed one of the Hall receiving signals on the controller.
Kelly offered to repair it but I was too lazy to return it :roll:
pks   100 µW
100 µW
Post by pks » Jun 03 2018 10:13pm
The black and red pin on hall controller shows 5V without a problem. Kelly has actually replied saying that hall circuits are pulled up to 12V through a resistor inside KLS controller.
I think something odd is going on with my motor. :)
I am testing my hall sensors in the motor (MXUS 3K Turbo) and both sets are showing strange results. I only connected +5v and ground to the motor hall sensors and each sensor goes to 0.001v or 0v. It switches between these two values reliably well, yet my understanding was that hall sensor should switch between 0v and 5v.
The motor also has 2 sets of sensors and it is brand new. Surely I could not damage both sets exactly same way.
Any guesses why my halls are behaving like that?
eee291   10 kW
Post by eee291 » Jun 03 2018 11:26pm
Did you measure from the positive to signal?
amberwolf   100 GW
Post by amberwolf » Jun 04 2018 2:35am
halls just switch ground on and off, so without being connected to the pullups inside the controller, with power on, you can't see the switching happen.
eee291   10 kW
Post by eee291 » Jun 04 2018 2:50am
Well the controller can tell you if the Halls are switching or not on the Programm info page.
cwah   10 GW
Post by cwah » Jun 04 2018 4:05pm
Maybe the motor hall? Worth a test
pks   100 µW
100 µW
Post by pks » Jun 04 2018 4:40pm
I'm a little confused. I was testing hall sensors between ground and signal. Is this is not the right way to test?
What is the right way to test the hall sensor in the motor without a controller connected to it?
pks   100 µW
100 µW
Post by pks » Jun 04 2018 4:42pm
eee291 wrote:
Jun 04 2018 2:50am
Sadly in my case the controller insists that halls aren't switching and I can't understand why. Nothing major changed in the motor and suddenly both sets of all halls are dead? Doesn't make a lot of sense.
eee291   10 kW
Post by eee291 » Jun 05 2018 12:39am
Maybe you cooked the motor above 110° for a longer time?
If you apply 5v to the sensors, then measure from the red to the three signal wires. If there is no switching then they are dead. Simple as that.
Or the wires have been tugged on accidentally.
Also what motor is it?
amberwolf   100 GW
Post by amberwolf » Jun 05 2018 12:59am
As I said, you have to connect the halls to the controller's pullup resistors and power ot test them.
They only switch ground on and off, so they don't output any voltage on their own. If you don't have pullup resistors on their signal wires, there will be no output above ground.
If you dont' connect them to a controller, you have to make your own pullup resistor and voltage source to test them with.
There is troubleshooting info on the http://ebikes.ca page on the Learn tab, if it helps.
DirkB19   10 µW
10 µW
Post by DirkB19 » Oct 05 2019 11:45am
Did you find the problem ?
I have a kinda similar problem.
I changed my QS motor and the Kelly KLS7812S now says : Identify Err; Hall sensor Error
No values are in the Hall Sensor fields, nothing moves here if I turn the wheel...
But, measuring between +5V and Hall Sensor wires shows a nice switching signal as I turn the wheel, so then I guess my
Kelly controller is no longer able to read the Halls ?
It worked fine on my previous similar motor...
Any clues ?
Thanks
pks   100 µW
100 µW
Post by pks » Oct 05 2019 12:07pm
In my case the problem was traced to faulty throttle and once it was replaced, controller started working just fine.
