Audisport09 said:
I not sure what windings they sent. Can you understand this? QSWP724000W 220305 1091050. Anyway I asked for 3T. Based on my understanding they all perform the same. Some need higher volts and some need higher phase amps of which I have plenty with lipos and BAC8000.
Yeah there’s a big difference between the windings. With QS motors they offer 3T, 4T, 5T, 6T
The 3T motor is good for top speed. It’s not efficient at stop and go or does it have a good acceleration from a standstill. That motor shines once you’re going over 15 or 20 mph. The 3T also can get really hot in stop and go traffic as it’s meant to be held wide open, so it’s best for commuting.
The top speed of the 3T winding @ 72v is around 70mph
Then compared to the 6T it’s all about acceleration. This motor has really hard acceleration but it lacks top speed. With the 6T it runs more efficient at stop and go and has the fastest acceleration of all the windings.
The top speed of the 6T winding @ 72v is around 40mph
Now all this being said you can still get decent acceleration out of the 3T but it takes way more amps compared to the slow wind motors like the 6T or 5T.
I can give you a example from my own personal experience with two different QS205. One is a 5.5T which is an odd winding and then my other motor is a 6T. There’s a massive acceleration difference just from 1/2 a winding. So comparing the 3T vs 6T is literally night and day difference for acceleration and top speed.
Unfortunately there’s a lot of misunderstanding about the motor windings. In fact when I first started building E bikes I was instructed the same that the 3T is the same performance, couldn’t be further from the truth.
Maybe QS would sell you a new stator with a 6T winding or if you have the skill you could rewind the motor but it’s a lot of work. Also with the 6T winding we typically have to special order it because their most popular sellers are the 3T, 5T so those they keep in stock.
Here’s two videos to my Enduro frame which has a 6T winding laced in a 16” rim. You can see it has good acceleration off the line. The controller was set at 150 DC amps. My controller goes up to 250 DC amps but don’t think it’s possible to go full throttle without looping out into the sunset lol
https://youtube.com/shorts/oDLMKu5hdIQ?feature=share
https://youtube.com/shorts/YiVQHncTpRA?feature=share
