jmac
The bike I'm starting with is a 1996 Raleigh M50, 22". Was purchased new... 20 years ago. My health has meant I haven't been able to ride it for most of that duration, but I've pulled it out every few years and serviced it, replaced components, etc. I fully ackowledge that I am using this frame for nostalgia purposes rather than any good reason.
Pre-Conversion Setup:
Essentially stock as listed on http://www.bikepedia.com/quickbike/BikeSpecs.aspx?Year=1996&Brand=Raleigh&Model=M50&Type=bike unless otherwise indicated.
It's always been used primarily on-road so has had http://www.tiogausa.com/city-slicker.html for tires. I believe, based on wear, that these were the original tires. The bike only had at most a couple hundred miles put on it before I got too sick, and then too injured (yes, I've done both!) to ride.
Post-Conversion Setup:
500w Rear DD Hub Motor @ 36V
Acera SL-M130 Shifters (replacing Acera ST-M290 integrated shift/brake, the right shifter was damaged)
Included Brake Levers
Schwalbe Marathon Plus 26x1.75 Tires
10s1p Lipo
Remainder will be stock
There's definitely a budget aspect here, because while under the supervision of my cardiologist I'm stationary biking about 15 miles a few times a week, I don't know how that is going to translate to actual bike riding. I have a Mark 2 setup priced out and on a wishlist that is about $1500 that should make me very happy if ebiking works for me.
Electronics is a hobby of mine (both low and high voltage, I built my first tesla coil at age 12). I am fully capable of designing and building a motor controller from the ground up, for instance, but I don't intend to go overboard on this setup beyond debugging. I'll just get it out of the way from the start, I'm an international award-winning photographer so most of the photos are going to suck because I can't be bothered to bring work cameras home with me anymore.
My goals for this setup:
1) See if my body holds up to riding.
2) Determine my needs/wants for range and speed.
3) Convince my wife to get one.
Also, I apparently forgot to finish this (I saved it as a draft) so obviously forgot to post it. It's slightly outdated so I'll just follow it up immediately with another post. As soon as I wander out to the garage to take some pictures. Note to anyone else that does it: Load Draft instead of View/Edit actually lets you post the draft, hitting view editing and then save and repeating multiple times is useless. This has been a phpBB issue since 2008 apparently...
10s1p Lipo
