Question for anyone of you who might know.
Got a few 36v chargers from Ping set to 41.8v from factory, all good...
Had a local customer with a 48v Lifepo4 pack in need of a charger, so i opened it up, found the potentiometer and set it to 58.4v, hot glued it back down to secure it.
Before boxing it, i took the time to plug it into my e-BMX that has a 16 cell PSI pack ( lifepo4, 10ah ) that was not fully charged but close at resting voltage 56v .. charger kicked in, fan working, charging at 2.5 amps, all was well.. i disconnected and re-connected a few times, then shipped it.
Just got a call from customer to inform me that it blew up.. :x
I confirmed polarity, Blue=Neg ... Brown=Pos ..
he says the battery side fuse blew, he replaced it, it blew again, then 3rd time around the charger itself quit... :| .......
Did he reverse polarity and is not realizing it/admitting to it ?
His battery pack is fully drained so the resting voltage is no doubt lower than my test pack, the larger swing " could " cause a heavier drain but without instruments to test this, i'm just guessing..
Are these kingpan chargers physically all the same 36v or 48v and trim pot adjusted ? . or are there different models for 48v ?
I'm giving him a refund and calling this issue closed.. but would still like to understand how it failed...
thoughts ?
thoughts ?
