Well, good news, bad news. The repaired torque sensor works fine and was a fairly easy job. But in the process of all this work my temperature sensor is messed up. If I enable temperature feature the display starts up showing "high temp shutdown", even when stone cold and I have no motor drive. I did also swap out the controller in this exercise but I have a plug on my temp sensor to go onto the controller throttle connector. Enabled temp, etc, no joy. I went through all the settings and they seem correct so maybe it is seeing an open circuit on the sensor? If I disable the temp feature the motor performs normally and all other functions work correctly. I have double checked that the temp sensor is plugged into the connector. The pins are too tiny for me to check continuity back through the thermistor. Any suggestion as to how to troubleshoot this?
BTW, running 20.1-C.4, update 2, 860C display
