Sparfuchs
- Joined
- Nov 22, 2020
- Messages
- 305
Hello EV friends,
i built a e bike with a mxus 3k turbo, a sabvoton 72150 and a 20s6p pack with a 50A BMS. The seller claims that peak is 150A, but i got told it's unrealistic. My problem is that if i go full throttle it does wheelies but suddenly everything is "dead" and can't be switched on again (full charged battery). As soon as i connect the charger for a second and then disconnect it, everething works great again and the lcd shows about 83v. My guess is that it pulls so much power at full throttle that the voltage gets below 60v (Discharge Cut-off Voltage) for a second and tells the BMS to power of. Is that possible ? I'm also sure i could use better setting on my controller because i had max. Amps. Does someone know what i've to do or what settings i could try to avoid that ?
Thanks for your help
Best regards
Sparfuchs
Here the specs of my battery according to the seller:
Battery Model:72V 21Ah
Nominal Capacity (AH) :21ah
Nominal Voltage (V): 72V
Cell Source Resistance (mΩ) :within 38mΩ
Cell Specification :Use Samsung 3500MAH Cells
Cell Combination :6-parallel 20-series
Lifecycle:more than 800 cycles
Battery Size :300*200*80*260*50*70MM
Battery Weight : About 6kgs
Charge:
Way of charge:CC/CV
Standard charge Current:5A
Max Continuous Charge Current:5A
Charge Cut-off Voltage: 84V
Cell Overcharge protection Voltage:4.2V
Charge Temperature Range :0 - 45°C
Discharge:
Max Continuous Discharge Current:50A
Peak Discharge Current:150A
Discharge Cut-off Voltage:60+/-1 V
Cell Overdisharge protection Voltage:2.75V
Discharge Temperature Range: -20 - 60°C
Best regards
Sparfuchs
Charge:
Way of charge:CC/CV
Discharge:
