Hey Dudes,
This is a "continuation" of the problem with the hubs I ordered "open" (meaning shipped rotors in one box and covers in the other)
Anyway, seems that the bearings that were inside each side cover of the hub motor are too small (inner diameter) to fit the axle.
The current ones are shielded 6202z which are 15mm inner diameter while the axle is 16.85mm
You can see them here: http://www.ebay.com/itm/HE527-6202Z-Dual-Metal-Shields-Pair-Deep-Groove-Radial-Ball-Bearing-15x35x11mm-/272259818409?hash=item3f63f323a9:g:39IAAOSwhOVXctnO
Now, the question is, will 17mm inner diameter be a perfect fit for my 16.85mm hub axle?
and also, where can I find 17x35x11mm bearing? all I found for these measurements are some special tapered/angled bearings and these ones:
http://www.ebay.com/itm/QTY-1-17x35x11-mm-S6003-2RS-Stainless-HYBRID-CERAMIC-Ball-Bearings-BLK-6003RS-/391405059216?hash=item5b218f3c90:g:TTgAAOSwZQxW434Q
which are damn expensive because they are some hybrid ceramic alien technology bearings which don't seem to fit my simple needs.
EDIT: Found a model named 6003z that look just like mine and are really easy to get BUT they are 10mm deep instead of 11mm
Is that a problem? I read that they are used for ebike and bike axles so Maybe these are the ones that should have been on the motor in the first place?
Here they are also on eBay: http://www.ebay.com/itm/HE55-6003Z-Shieded-Deep-Groove-Ba-Bearing-17-x-35-x-10mm-A-/272238992481?hash=item3f62b55c61:g:HpMAAOSwuzRXdGJv
Any ideas?
Any ideas?
