thunderstorm80
- Joined
- Mar 29, 2016
- Messages
- 383
Hi,
I wanted to buy a battery pack from:
http://em3ev.com/store/
They are very nice and seems very professional, but I couldn't get one thing right - Their BMS.
Because I need regen, and quite powerful one, I was told their BMS can't accept more than 12A of charge.
I offered to to buy two battery packs in parallel, to split the load, so theoretically my max charge current is 24A. (+-)
I was told parallel connection is not allowed as it will force drifting currents between the packs via it's discharge terminals, and it's also problematic with regen.
That's where I got lost - The BMS separates different battery terminals for discharge and different ones for charge?
They said some regen is possible via the discharge terminal but it's not recommended. (and that's where I (think) I understood the regen current would arrive at the discharge terminal so the 12A-charge limit is not relevant - but never the less it would destroy the BMS circuit)
They said I could put diodes to redirect the currents right, but diodes get hot and aren't long term reliable at those powers.
Shall I avoid that kind of BMS and buy from them the pack without it? (They said it's possible)
Anyone has experience with their BMS and batteries?
If someone could show me what kind of BMS they use, and a circuit diagram - that would really help me to understand what's going on there.
Also - what kind of BMS would you recommend that is meant to cope with powerful regen. (and I guess that means it only has a single battery terminal for discharge and charge)
All I want is a BMS that will be passively drift current between the cells with dedicated signal wires on each cell's terminal, so it doesn't interfere with discharge/charging.
It should also be doing this constantly - and not only at 100% SOC, because I will not use the battery at more than 80%-90% SOC so it doesn't have pathetic life cycle count.
If I had enough knowledge in electronics I could have built something like this myself - with capacitator - connecting to each cell for a fixed amount of time before going over to the next one - and therefore perform passive and simple voltage balancing.
