Probably not such an informative topic but here goes.
I bought myself a bike:
https://www.ebay.co.uk/itm/Electric-Bicycle-/123040478799?_trksid=p2047675.l2557&ssPageName=STRK%3AMEBIDX%3AIT&nma=true&si=4Nwfh%252BHtzMxubY8stJc4HDtswbw%253D&orig_cvip=true&rt=nc
Nothing special just a first entry into the arena. It has no attempt to make itself road legal and I need to do that. To that end I have ordered a pedal sensor dodad from China and am attempting to make sense of the controller wires.
After several hours it is apparent to me that the controller is not bringing out all the wires I need so I am attempting to guess which connections are for the pedal sensor and which connection(s) I need to limit the power and speed to UK road legal requirements. I also need to add a power switch with key. I don't know if they normally have wires for that or if I should jsut use the brake sense wire to prevent it going anywhere.
The controler is clearly out of the same place that this one came from:
https://endless-sphere.com/forums/viewtopic.php?t=74562
My controller has 4 transistor H bridges so 12 in total, slightly smaller than the one in that thread. The pictures in that thread are almost good enough for me to work out the connections but after being left with streaming eyes trying to work out the letters on the PCB I gave up and thought I would ask if anyone has them.
My PCB connection points are:
SL EBS LED GND3 TB
DC XS GND2 (I think XS seems to be a resistive divider on the throttle resistance so it will slow it but not limit it)
PA3 PF4 PB7 PB6 CR PB4
+5V TA GND
BKL BKL BKH (Brake low, brake low, brake high ?)
SP- SP SP+
H1 SC SB SA H+ (Hall effect from motor)
SC1
These are probably for programming the micro and maybe for "higher functionality" like speed display, cruise control etc I guess)
RST WIM GND +5V +3V GND TX0 RX0
GND TB A AR-IN VB+ MCX1 MCX
Can anyone fill in the blanks. Googling the abbreviations doesn't help and though some of them seem obvious I would rather not blow it up.
Cheers.
SL EBS LED GND3 TB
+5V TA GND
SP- SP SP+
SC1
Cheers.
