maarten_almighty
- Joined
- Jan 10, 2020
- Messages
- 47
Can a shunt mod be performed in reverse; as in: make the shunt thinner such that max amperage drawn by the controller is less?
my controller is capable of 150Amps (DC battery current) but my current battery can only handle 70A (will upgrade in the future).
I would like to make the shunt in the controller smaller so it (the controller) only draws approx 70A or a bit less maximum.
Are there usually 2 shunts (1 for the DC battery amps and one for the phase amps) in a controller? If so how do I know which one is which? (most likely phase amp shunt will be thicker since the phase amps will be higher than dc amps).. Perhaps only 1 shunt is used? Please correct me if I'm wrong on this
Are there any negative consequences this (downsizing shunt) can have?
(I know the acceleration will be limited by this but that's fine by me, 70A should give plenty of torque imo, top speed shouldn't be affected I think since at the motor's topspeed at my battery voltage only 60A DC current should be drawn (approximately). Is this correct (should top speed not be affected by downsizing the shunt)?
I am working with a non-programmable controller (hence I need to do it via shunt mod instead of via software).
This is the controller I want to buy (9kw version): https://nl.aliexpress.com/item/33055639740.html?srcSns=sns_WhatsApp&spreadType=socialShare&bizType=ProductDetail&social_params=60005594459&tt=MG&aff_platform=default&sk=_BSKbYA&aff_trace_key=95e0245bd8a54d1a8f249db32258e951-1608992028480-07719-_BSKbYA&shareId=60005594459&businessType=ProductDetail&platform=AE&terminal_id=40d9f3f985c84148bb2e58704e805c2a
Thank you! :wink:
Thank you! :wink:
