Your Dahon (unless it's the larger MTB style folders) have 80mm fronts. Not too many motors have those widths. How do I know? I had to buy a wheel/motor kit for a newly purchased Tern (a folding bike company very similar to Dahons). I found two sites that offered 80mm motor/wheel kits. The 1st I found was ridiculously high priced. The 2nd I found was at BMSbattery.com thanks to another veteran member here. Check out that sight and you will see your avenues opening up. Don't forget, if your bike has 20" wheels, get the high RPM versions, otherwise you get a slow EV and you'll be disappointed at it's lack of power.
If I had the chance to go back in time and make the purchase again for this style of bike, I'd get the high RPM version & a 48V battery (I purchased a 36V). Just a tad more noticeable power & speed at that voltage. If your a lipo guru, you could even run it at 60V as long as your careful when pulling higher loads (i.e. big hills, very stiff headwinds) without burning the motor from excessive heat.
My advice? Sell your folder. The 80mm front is an obstacle in a world where the standard for ebike front hubs is 100mm. If you need the bike to be foldable, get the larger MTB style folders with 100mm fronts. Or a swift steel folding bike (similar to Dahon's but with 100mm fronts).
It's a shame when you search bicycle specifications that leave out the stuff ebikers want. For motor in wheel builds we want either front fork widths or rear dropout widths. For midmounted motor builds we want the bottom bracket length. :|
