The BMS is a JBD Universal Smart BMS type AP21S001
It can do both LFP and Li Ion and series connections between 6s and 20s
Out of the blue, about a dozen times now it decides to stop working. The voltage at the connector ends drops to 15-17v while the pack voltage remains normal at around 50+ v fully charged with perfectly balanced series modules.
The only way to fix it is to unplug and replug the JST connectors for the balance leads. There are 2 sets of JSTs for the balance leads, the main one with the larger group of strings however does have a broken clip on top. That being said, it fits snugly in place and even though I'm getting the low voltage at the connector head end everything checks out and looks fine in the bluetooth app.
when I wired it up the first time I admit that I had some of the balance leads wrong but only for a few minutes. For the smart BMS, for lower series count batteries you have to connect 8 of the balance leads into one. on Sriko batteries website though they had the manuals for the 20s version and the 21s version reversed. Could this be the culprit and have damaged the BMS?
I did take off the heatsinks from both sides and examined the board. No signs of any fried components.
What I can say is that the problem is not: The cells, the spot welding, the configuration of the balance leads, short circuits in the balance leads, continuity in the balance leads between the male JST and the its series connection, or poor connections to B- and C-.
Any wisdom is appreciated! Happy to send more details about the issue.
