Hello all,
After electrifying my Quest velomobile with good success, I'm looking to apply the same recipe to my QuattroVelo. That is, a motor driving the cranks that "sees" all the gears. Only this time, instead of using a geared Headline motor, I want to install a low-power (read legal 250W or less) gearless hub motor, Stokemonkey-style, for the following reasons:
1/ The motor powers the cranks, so I can run it at its most efficient speed to match my prefered pedaling cadence at all time, regardless of the gear I'm in. I don't need a lot of power to climb anything or reach a decent speed on the flat, since it goes through all the gears.
2/ I use the e-assist very seldom, When I don't, I want to keep my on-board battery topped up to run the indicators, lights, satnav, cameras etc. On my Quest, I have a separate generator and a separate battery to do that. On my QuattroVelo, I want to try and use the hub motor as a generator when it's not used as a motor, and use the e-assist battery as my sole battery. Hence the need for a gearless motor. I'm aware that such motors have drag and cogging when they're not powered, so maybe (probably) it won't be practical. If it isn't, I can always make some kind of disconnector to disconnect the motor from the drivetrain entirely on the fly, and install a separate generator later. Or perhaps run just a little power through it to overcome the drag when I'm in "bike mode". But I'd like to try.
So I need a gearless hub motor with a 6-bolt disc rotor mount to install a sprocket on the left-hand side that'll drive the chainring on my left-hand side crank.
The problem I have is, the chainring in question is 75 teeth, and can't be any smaller because of the gearbox I use. So to keep the sprocket reasonably small, and to improve the motor's efficiency, I want to go for a motor that spins faster. Depending on the sprocket I choose, I'll need a motor that spins between 300 and 430 rpm at maximum efficiency. I figure a hub motor designed to be laced into a 20" wheel would do what I need. The trouble is, I've looked at many potentially suitable hub motors on various Chinese manufacturers' websites, but very few of these manufacturers publish the RPM/power/efficiency curves for their motors.
So I'd like some advice from you specialists: can anybody recommend a suitable, good quality smaller wheel hub motor that would meet my requirements?
Thanks!
Thanks!
