pwd,
The GEN3 spindle would have been short for the present QS3000 set up. So I did add an Isis shaft section to the Lightening Rod Isis BB spindle [nominal 100mm Isis BB] that was about 3” too short.
A 3” end section on a short Isis crank was cut off employing a skinny wheel grinder for cutting the lathe spun BB spindle.
Here is the cut off Isis end to be attached to the LR spindle. The shaft hardening did not penetrate to the surface of the longitudinal hole so drilling the hole larger is quite easy.
Next a bolt was threaded into the LR Isis spindle
The tightened end bolt (M12 x 1.0) was lathe turned down to tight-fit into the add-on Isis shaft end. But before hammering the shafts together, the splines were aligned so the pedal crank arm attachment would have exactly 180 degrees rotation separation of the arms.
The short Isis end was dead blow hammered down onto the LR Isis spindle. Here is the snug result:
A small width circular cut was ground around at the joint to permit more welding surface. This length addition was clamped before welding.
Here is the welded longer Isis spindle….
A eutectic high alloy electrode [4036] was used
A long square end spindle next to the fabricated equal length Isis spindle. [weld has been ground]
The lengthened Isis spindle placed on the bottom of the QS3000 motor frame for size comparison
The lengthened spindle still will need some zones turned down for the bearing to slide into what become the BB bearing zone. If the final bearing position is where the shaft is undersized I will fit the bearing with shim stock or weld the zone up and lathe turn it down to a snug bearing fit.
