Jorad
- Joined
- Mar 16, 2010
- Messages
- 4
Hey all!
I'm Jorad! I've been lurking and I finally got 4-1/2 bikes to cut apart and build my 2 seater trike. I am planning on using:
Motor:
Turnigy 80-100-A 180Kv Brushless Outrunner (eq: 70-55)
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=5139&Product_Name=Turnigy_80-100-A_180Kv_Brushless_Outrunner_%28eq:_70-55%29
ESC:
Turnigy Monster-2000 200A 4-12S Brushless ESC
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=10332
and a few a123-M1 cells like in this post: http://endless-sphere.com/forums/viewtopic.php?f=14&t=2498
My problem is I know I want ~30-48v but I have no clue as to the whole parallel vs series configuration.
I was planning on getting a couple of the cordless drill battery packs and just have docks that I could pop them into without having to modify the battery itself. That way I could use the original charger for them.
I'm still working on the 3-d model of my trike (not technical just for approximation) and I was wondering if there was anything else I needed in the construction of this. Have I missed anything, can I use a less beefy ESC? I thought I read about having to add a hall effect sensor seeing as this is an outboard motor, would I?
One other thing I need to know is what kind of drive system do I have to use. I originally thought I could just hook the motor up to a sprocket for a chain or a belt and go. Now I'm not sure.
I apologize if some of this has been covered, I have used the search function since I joined but there are literally hundreds of pages to wade through to get answers and most of the time they are conflicting.
Thanks for the help and I look forward to sharing with everyone what I have built.
Motor:
ESC:
