Hey family,
Been a while ! I need some of you support. I bought a cheap S73 and replaced the original hub motor with the MXUS 1000W hub motor. It was provided with the KT36/48ZWSRL ESC (30A Max rating & Continuous 15A). It works fine on the bench but the ESC is too big for my enclosure and I would like to use a KT36/48SVPRM (25A Max rated & Continuous 12A) controller but the color coding for the sensor does not match between both controllers.
I've started to try some combos but according to GPT there are 120 distinct combinaisons and I also read that here that it was closer to 36. So I'm lost.
Any one have already done such thing (I'm surprised that the same KT controller range is having different color codes! seriously !! why !
Anyone has a correspondance table so I can make your MXUS motor work with the KT36/48SVPRM controller?
I'm also happy to spend some money for a hall sensor autodetection controller (if only KT would have got this feature) but Phaserunner is no more sold and I need a pretty small controller such as the KT36/48SVPRM to fit in my original "box/seat"
Thanks all
Thanks all
