wilcwilc
100 µW
- Joined
- Mar 7, 2020
- Messages
- 8
Riding custom ebike, 48v 2000w rear direct drive hub kit from China, 52v 28ah rear rack battery.
Traveling in rain for 3 days. Bike map app sent me down muddy dirt road. Road out 1/2 mile down. Turned around, slight upgrade, bike struggling in on muddy road. Bike cut off 100 feet from tar road. Controller very hot. I was getting error message, Motor or Controller Short Circuit Fault.
Harness casing to motor overheated and melted 4 inches away from controller connections.
I stripped harness casing to point where motor wires weren't melted. Pulled 3 melted motor wires apart. One wire pulled casing off. Repaired with electrical tape. Retaped harness casing with gorilla tape. Wires near controller were fine.
Speedometer wasn't working properly after this.
It would turn on automatically when battery turned on. Controls didn't work. Stuck on 3 setting. Tested by lifting motor off the ground. Ran fine. Got back on road. Went about 2 miles before I thought battery was shutting me down.
Battery was low at 42v.
Guy gave me a ride to motel. Charged battery.
Left next morning. Speedometer still not working. Went less than 1/4 mile before shut off.
Back to motel. Later in day after Speedometer dried out, it started working properly. Could adjust all settings with buttons.
When tested though, would still cut off after a few seconds of riding if given to much throttle.
I could turn throttle slight, on and off, on and off, and I could ride around parking lot. In room, if I lifted tire off the ground, it would do 45 mph continuously with out any cut off. I can still see moisture behind Speedometer screen. Speedometer cuts off after turning throttle to more than 5-7 mph. But not when I lift rear wheel off the ground, when more thrust is required on the ground.
Why? Please help.
Thanks for any suggestions.
I only have speedometer, throttle, battery, and motor connected to controller.
I'm on long distance journey and want to get back on the road. Rain stopped, thank God.
Mike Wiltse 813-447-7912
Why? Please help.
