Bike info:
1000 watt rear drive direct drive.
48V 20AH battery pack SLA CHROME
Goes only about 5.3 miles before dieing
Hello everybody, I just recently bought 4 20 amp hour SLA CHROME batteries, About 2 months ago. I only recharge the bike every other day as I only use it every other day and I don't fully discharge it, I just use it for small errands around the town and then I recharge it right afterwards.
I inadvertently was running a battery with other batteries nearly discharged. I was using it for experiments and at the time was not experienced enough to understand that they all need to be balanced to be used them. After I realize what the problem was I charged up all the batteries individually with a 12V smart charger. Also connect them all together in parallel and let them sit overnight. I also tried discharging them with my power inverter at 130 watts until it beeps about 10v and shuts its self down and then recharge them.
The main problem is every time I go to charge up the batteries individually on my 12 volt smart charger, it says that it has 92% capacity of charge. And that can't be true because the bike dies out below 42 volts. I would expect that one of the batteries might have lower capacity of charge compare to the rest which is causing the whole pack to die prematurely. But they all seem to be level and have the same voltages.
My ebike says the battery's dead then quickly rise up to voltage showing nearly full charge around 52 volts or abit less.
What test should I do to try to find the problem battery unless they're all problem batteries they're just so new so hard to believe that there at the end of their life.
Thanks,
Thanks,
