johnws6
- Joined
- Jun 2, 2008
- Messages
- 47
I ran across these silicon carbide schottky diodes and am wondering what everyone's opinion who has used them or thinks they would work in a charging system for nickel based batteries. I have a setup of 4 packs of 20 nimh cells in series and want to set up a charging method where I don't require to disconnect each pack to recharge. Each pack has it's own wiring circuit but I want to add these into the charging wire leads to prevent the possibility of a short if the charging terminals should ever contact anything conductive.
I previously tried out a high power diode I picked up off ebay that was for solar applications rated at 15 amps and it tended to heat up ( as anticipated ) while charging, at 2 amps. I would like to be able to charge at 4 amps if possible. I have the packs protected from each other with diodes in the power leads before the parallel connection as well but am concerned with the voltage drop and heating of the diodes in the charging circuit and am thinking these may work, or am open to any other ideas that I'm over looking possibly.
http://www.digikey.com/product-sear...e=us&keywords=C4D08120E&formaction=on&x=0&y=0
