markw
Hi guys,
Recently completed my bike build (post incoming! ) and started some tests. Took it on it's longest journey to date today and something bad happened.
Bike ran out of juice. Ffffuuu--- . Should have checked the voltages more closely before leaving to go home. I pedaled home (10 minutes) and got the batteries hooked up to the charger in parallel via a balance board. Here's some stats to help unnastand the picture.
5s Turnigy Softcase LiPo 3s2p
After recording voltages for each pack I found that pack #2 might be suspect. Cells 1-5 as follows 2.8v / 2.7v / 2.06v !!!!! / 2.95v / 2.96v.
I did not heed some of the advices from this post http://endless-sphere.com/forums/viewtopic.php?f=14&t=52240&hilit=lipo+rules --- none of the cells were individually balance charged and I think this was probably my huge blunder. For SHAME! I know *bows head in shame.*
All cells are currently parallel balance charging and afterwards will be individually charged to 4.10 and then I intend on throwing them back on the wheels for discharging/fun/monitoring. Unless:
Please advise. Should I just dispose of pack #2 right now? Is there hope for its recovery after respecting it a bit more? It cell 3 in pack #2 was far below safe voltage... for nearly 20 minutes only. When I run my fingers down the top/flat sides of the pack it doesn't feel puffy or bulgy.
http://i.imgur.com/hKOlheD.jpg (pictures of the packs and my charging setup :s )
http://i.imgur.com/7YKLSol.jpg (pictures of current charging stats.)
Thank you ES!!
Thank you ES!!
