There are 7s chargers ( up to 8s ) available now, one for around 50 US $ , at H.K. I have one and it works great. And I use the Balance mode every time I charge , I most often just charge 4.16-4.18 volts or even less, per cell.
it seems to keep them within a
.03-.04 difference for all packs. ( mostly .02 difference max between all the cells in the pack. )
and
Contact iSDT in China, they make great little and powerful 6s DC chargers now, However they said that latter this year they are are going to be offering/selling their newest model which will go up to 8 cells.
I say contact them because the more people who contact them and ask them when they are going to make a DC charger that charges up to 8 cells ( 8s ) the faster I think they will make it available.
Not sure what final voltage you want to go with, Zippy makes higher C rate 7 s batteries . ( I have 4 of them ) they are all lower amp hours, so there would be more of them/ more connections.
However with 5.5 mm bullets I find connections simple enough. ( I have a different color heat shrink , a small band that I put on the Red + wire of one pack and Black - wire of another pack and then I connect those two packs into series.
that makes the connections simple and makes for a quick double check of connections )( to further make it simple I label the packs 1 & 2 , and 3 & 4 , always connecting packs 1 & 2 together and packs 3 & 4 together )
Making your own Parallel Harness is very easy.
Less connections to to deal with in the balancing scenario ? ? Each Lipo pack has balancing wires / plug that plugs into the charger . and if using a Parallel Charging Board, they have the correct number of connections/plugs .
So if the 7 s packs or even 8s packs will fit into the frame better , you could get them. As far as having allot of batteries, I just make it simple by using 4 together in a Series/Parallel set up, then when going for further distance , just un plug them and plug in another 2 packs during the ride, there is always a reason to stop, weather riding the Road or Off Road.
Remember, very important if you are going to make a high power e-bike, the Multistar's are only 2 c rated, meaning in reality you should only pull ... 0.5c that means one half of 1 , continuously.
A RC Helicopter Pilot I know , Only ... uses 45c or higher c rated batteries !
John Bozi said:
smaller packs are better to weed out the dud cell. My counter argument to this is I will be more likely to balance charge more often 4 batteries instead of 8, 12 or 24 for that matter.
price per watt is higher for sure but again, I would be happy to pay extra to have less connections to deal with in the balancing scenario. In this case NO parallel harness too.... I would probably cut off the xt90s and crimp in some gold bullets for daisy chain too.
why not 7s? there are tons of cheapish 6s balance chargers, a lot of those odd packs last time I checked a year or so ago were all double complexity to charge something like a 3s + 4s...
mentioned on another thread
